Old 22nd March 2010, 01:53 PM
entwisi
Guest
Posts: n/a
does sound like a clutch basket as mine did it ( check my posts for pictures of it )
I could drive mine just about but felt like it was stuck in 5th rather than 3rd...
Good luck mate
Old 22nd March 2010, 05:34 PM
Just drove to Bens (60 miles) took it easy, first part of the journey it drove fine like nothing was wrong with it and no limp mode. 1,2,3,4,5 gears all smooth then I had to stop to pay the M6 toll and the car slammed into gear and jerked and all box lights lit up again. Turned of car and restarted, it struggled to get moving a little like it was revving in neutral while slightly going forward then slammed into gear before continuing the rest of the journey quite smoothly. I tested the tiptronic
at 40 and gears changed smoothly. 3,4,5. So the problem only really occurrd from standstill. I didn't push it hard at all though.
It's in Bens very capable hands now. Thanks for accomdating me at such short notice mate, see you tomorrow for the newly aquired A8s ATF/health check and maf change
Old 22nd March 2010, 07:02 PM
B@fink B@fink is offline
if it worked properly for some distance it might not be completely goosed? clearly something big can't have dropped off in the gubbins if it drives! Cross your fingers and hope its just fluid level.....best of luck!
Old 23rd March 2010, 09:09 AM
builder22 builder22 is offline
Hey there,
That sounds just like what mine is doing, Ben can tell you the horror story . I would be very interested to know how (if) you resolve this one as it might shed some light on my situation other than having to replace the gearbox which unfortunately i cannot afford at the moment.
Good luck with it - it is not a good place to be in.
Niall
Gone, but not forgotten...
2000 A8 4.2 Quattro – Green, S8 18’s, Xenons, PhatBox, and loads of other toys.
Old 23rd March 2010, 05:32 PM
Ben thinks he may have found the problem, he pressure tested the gearbox and there was a blockage which he flushed out, next thing he is going to do is an ATF change with Audi oil and all associated O rings, seals, gaskets, strainer etc may do the trick but its not 100% yet. Hoping for good news, but preparing for the worst!
Old 24th March 2010, 11:28 AM
Box is very poorly, had the opportunity to buy a very nice final edition S8 with a rebuilt box just recently and guess what? I passed on the opportunity. You wouldn't believe why, but I really love the green now, it went from hateish to love. It looks stunning and its possibly the only D2 around in this colour so that makes it even more special, so I can justify pouring money into my car.
To the rebuild: http://www.vmtp-midlands.co.uk/About.aspx
Has anyone used these guys?
They are a ZF agent and a quick chat on the phone has filled me with a lot of confidence already, not to far from Ben's place either. So I'm ready to go ahead with this now. Is the gearbox super duper smooth after the rebuild then or won't I notice a difference? It was fine beforehand, no hunting or slipping, it came out of nowhere.
Old 24th March 2010, 12:10 PM
Looks ok, but they only give a 12 month warranty.
Old 24th March 2010, 01:04 PM
Box is very poorly..
Hey there,
Was Ben able to tell you what went wrong with your own one? Or was it just a without failure any specific reason?
I'm just wondering as my one is giving me some trouble (still drivable) but not great all the same.
Niall
