Old 29th February 2016, 12:36 PM
It does sound rather like a dodgy F125 switch doesn't it
Confirmed by VCDS scan. Clean apart from 2 codes, one of which is a regular, the other the F125.
The usual: 01119 - Gear Recognition Signal 35-10 - - - Intermittent
The expected: 17090 - Transmission Range Sensor (F125): Implausible Signal P0706 - 35-00 - -
I didn't clear it, though maybe I should?
Old 29th February 2016, 12:47 PM
I cleared both codes and had a little potter back and forwards on the driveway, all fine and no codes returned.
Wait and see at this stage I guess, next trip is probably tomorrow afternoon/evening.
Old 29th February 2016, 04:36 PM
F125 can come and go - moving it to R or D will make it likely to come on. If you start a journey and get to D without triggering the fault it won't come on at all until you next move the gear selector
Be warned there's 2 types of switch with different plugs so order from TPS with VIN to make sure you get the right one. Costs about £150 IIRC and bit of hassle to fit as box needs to be dropped a little to access I think, so one exhaust pipe off from memory
If it's due a box service it makes sense to do at the same time as it'll save some labour
Old 1st March 2016, 10:28 PM
Adrian, I'll probably get it all done by Guy sometime soon.
Had a few journeys since the "glitch", all totally fine.
Old 2nd March 2016, 07:47 AM
Mine does this once in a blue moon. If there is a pattern to it, it seems to be when I've reversed the car out of the garage to wash it and then driven it back in and left it. Next day it very occasionally goes into limp when I engage reverse again. Turning the ignition off and back on again always clears it.
I'll probably get it done at the the next gearbox service later this year.
Old 2nd March 2016, 08:10 AM
Mine used to do that when I first bought it years ago. Disconnected and cleaned the F125 switch connections; never done it since.
Old 3rd March 2016, 07:32 AM
Mark, was that just the wiring plug (8-pin I believe) or did you remove the unit from the gearbox?
Old 3rd March 2016, 07:42 AM
It can be done in situ, although on a ramp would help!
For an intermittent connection issue that appears unrelated to moving the gear selector, it'd be worth a try. If the symptoms seem to relate to movement of the gear selector it's more likely to be mechanical wear in the unit so no amount of cleaning the pins will help.
Old 3rd March 2016, 07:46 AM
The limp mode the other day is the only time ever that moving the gear selector has had any unexpected effect.
Old 3rd March 2016, 11:18 AM
Just the wiring plug. Unplugged it, cleaned the pins, applied some contact lube and connected/disconnected it a few times.
The plastic undertray was missing when I bought the car, which I think probably left the connection a little more exposed than usual.
