Old 3rd March 2016, 08:28 AM
Originally Posted by Lee S View Post
Does it have the standard camshafts fitted and if so are they worn or are the followers worn? Are the followers hydraulic or solid? Sounds like the temp thing could be something to do with it. Like the cam followers if hydraulic are not pressurising correctly until the oil is sufficiently warmed. Maybe?
We like this idea most at present - The car did idle notably better after the service, which I'd assumed was the sparks/coils.
It could well have been some decent new oil that was slightly thinner and helped as the old stuff was well past it.
Will run an engine flush through it me thinks asap and see what happens...
