D3 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
Hi Scott.
The TPMS module (J502) is located under the rear bench seat and is powered with a 5A fused Terminal 30 supply. That part of the wiring is fairly simple. Then take the CAN wires to the CAN separating connector block on the left hand side. Simple, but you've got to remove all of the internal trim. Next part is to wire each tyre pressure sensor aerial back to the J502 module. Each aerial is located behind each wheel housing liners, a bit of a pain but do able. Did you get the aerials and retainers with the module you bought? Can't comment on what other sensors will work. Hope that helps ![]()
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 9th March 2016 at 07:59 PM. Reason: added picture |
