Old 27th March 2010, 06:48 PM
DJStrange
Guest
Posts: n/a
Thanks very much for your help Mike and AVPerformance
I've been reading around about the wayne angle blocks and those anti-foul sockets, figured that method is going to be the cheapest option to see if I can get the code to stay off for some length of time. I've got a couple on order (designed for the same purpose on hydrogen hybrid motors) for less than £20 - still cheaper than if I'd gone to audi/specialist for a diagnostic.
I presume that a remap is what you are suggesting AVP? I'd be interested if I was keeping the vehicle, but I just want to get it fixed up ready to sell now. I'll keep it in mind though as I can't sell a duff motor, unlike the guy who sold it to me...
Anyone in the market for an '02 S8 on 130k watch this space (still a few other jobs to finish yet)
Old 6th April 2010, 02:56 PM
A8 Doc A8 Doc is offline
Foulers work a treat. Used them as a temporary measure on the M5 until I mapped them out
Old 9th April 2010, 07:31 PM
DJStrange
Guest
Posts: n/a
Well, I struggled to get the o2 sensors off, so I ended up taking the cat pipes off. Got one sensor off, fitted anti-fouler, refitted sensor no worries.
Next one, the sensor would not budge - then I noticed the guy who did the welding fitted the pipe & welded close to the sensor weldolet, so he's basically welded the sensor inside the weldolet. Had to break it out and chop it.
So, I need a new sensor and someone to tap the weldolet with a new thread, possibly even a new weldolet and pipe welding on yet, have to see how knackered the thread is.
The saga continues...
Old 21st February 2011, 09:28 PM
Ben, can the chip be re-coded to code out the post-cat lambdas?
I have had Wayne blocks on my car with 100cel cats for 2 years but have had some intermittent errors for the rear lambdas after the first year (but no CEL yet). I would like to just do away with those pesky rear lambdas.
I tried changing the engine code as per Tobes's instructions back on tyresmoke forums, but it wont take the code for Euro II. However it will take the code for a manual gear box for example, so perhaps the Euro II program isnt loaded on the ECU. Is there any other way to code out the rear lambdas without having to get a new chip?
Tobes' instructions:
"You need to select, Engine 01
then check the coding box,
This is the coding table
* ??xxx: Emissions
o 05 = Euro II/D3
o 06 = TLEV (USA)
o 07 = LEV (USA)
o 08 = GUS/China
o 10 = Euro III
o 11 = Euro IV/Japan
o 25 = South Africa
o 26 = Mexico/Taiwan
o 27 = Brasil
* xx?xx: Powertrain
o 5 = Front-Wheel-Drive
o 6 = All-Wheel-Drive without ASR/ESP (with CAN-Bus)
o 7 = All-Wheel-Drive with ASR/ESP (with CAN-Bus)
o 8 = All-Wheel-Drive with Post-Switch Stage (Low Range - A6 Allroad only)
* xxx?x: Transmission
o 1 = 6-Speed Manual Transmission
o 5 = 5-Speed Automatic Transmission (01V)
* xxxx?: Vehicle
o 2 = Audi A6
o 5 = Audi A6 Allroad
Write down the old code, The first 2 digits are whet you need, So if yours are 10 you need to change it to 05"
The above private message was as a result of this thread:
http://www.tyresmoke.net/forum/audi-...s-removed.html
Also, I was looking up lambdas on Elsawin, there is a bizzare statement on there that seems to indicate that rear lambdas take priority over front lambdas? I hope I havent affected fuelling by removing the rear lambdas out of the flow of the pipe. Seems a bit crazy to me I thought only front lambdas affected fuelling? (unless I mis-interpreted the upstream-downstream terminology)
Thanks
Name:	Lambda control.jpg
Old 10th June 2012, 11:30 AM
Default another thread resurection
just been searching and found this post, has anyone found a successful solution to this? I have sports cats which seems to cause the Engine Management light to come on had it checked and its related to post cat sensors, I know the Laird got some extensions fitted to his but as its now Davids car and he had the same problem last weekend doesnt look like that worked long term either.
thanks for any help
cheers
Old 10th June 2012, 01:36 PM
Software needs to be modified in similar manner like remapping. It needs to be read from ECU, modified and written back. A8 Doc or Mkoneman should be able to help.
