Ah, maybe the same on mine? I will check...
I had the adaptive NS headlight permanently pointing to the pavement. Also ,the corner assist NS lighting coming on at random (at all speeds). Got the following codes: Address 55: Xenon Range Labels: 4F0-910-357.lbl Part No SW: 4L0 910 357 HW: 4L0 907 357 Component: AFS 1 H01 0040 Revision: 00000001 Serial number: Coding: 0000018 Shop #: WSC 02313 785 00200 VCID: E9DF4BFFC0FBB056AC3-80BC 4 Faults Found: 02627 - Dynamic Cornering Light Motor; Left (V318) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00111010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 153 Mileage: 229915 km Time Indication: 0 Date: 2016.03.07 Time: 18:01:12 02627 - Dynamic Cornering Light Motor; Left (V318) 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 153 Mileage: 229921 km Time Indication: 0 Date: 2016.03.07 Time: 19:16:43 02235 - Stationary Cornering Lamp (Left) (M51) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 2 Fault Frequency: 6 Reset counter: 200 Mileage: 229941 km Time Indication: 0 Date: 2016.03.09 Time: 18:23:17 ------------------------------------------------------- Quote:
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment ![]() 2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot 2022 Mercedes EQC 400 Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS 2008 A8 3.0 Tdi sport, B&O |
Only just got around to this job.. I'm struggling to locate the connector. It does not appear to be in the same place as the pic from Borys on mine. I will have to check the tech guides.
It's the connector at the end of the loom right in the middle of your photo, that goes to the level sensor.... just from a different angle and with the splash guard still on.
Lee 2017 Nissan Leaf Tekna |
Thanks. I pulled that and all was good in there. So the issue must be something else...
So I have spent the last few months looking out for a N/S headlight (4E09410064BF) but to no avail. And I checked with our sponsors (obviously)..
So my idea now is to simply buy a matching pair. Different part numbers. Is it just a case of changing the adaption to suit the different part numbered headlights? If so, how would I go about finding out what adaption to use? And I assume that the pre and post FL units will fit as long as it is coming from a D3 with a single grill 2005> I want to have a replacement to hand when I take the faulty unit out. Albeit that it may in fact prove possible to repair the faulty unit when I get in there. I can then always resell the units if I don't end up fitting them. With winter approaching now, I need to get it sorted... plus this is the only fault with the car on VCDS and it 'nags' me.
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment ![]() 2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot 2022 Mercedes EQC 400 Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS 2008 A8 3.0 Tdi sport, B&O Last edited by kele; 3rd October 2016 at 05:35 PM. |
