Old 14th May 2015, 08:51 PM
MAM MAM is offline
Originally Posted by MAM View Post
I have installed the bluetooth module, new connector and dongle. The MMI recognises that I have bluetooth and allows me to delete pairings and change the code. What I cannot do is pair my iPhone 3GS with it - The iPhone does not find the car.
Could this be due to the MMI software version? I am on a lowly 2120.
After finding out that my installed unit was fried - this could have been either me installing the MMI upgrade, or I bought a dud - I bought another replacement unit.
I have taken this unit and fitted it - and thrown away the fried one. It now works a treat.
One thing I aint doing is running disk 2 to update the phone module. At least this way I cannot fry the unit. The strange thing was that the first unit was only partly dead as much of the unit was visible to VAGCOM.
The only job left to do is get some to help at the annual meet to re-program the microphone and voice control as when trying to get the original unit working, the settings were changed hoping to get my unit working. My phone answers the calls but as the mic and voice control are set up wrong, I cannot talk to the caller. My voice control comes up as Button not used as it was re-set up to use the bluetooth in error.
Deep Green 2006 '56' A8 4.2 SE, B&O & Exclusive Interior
Extended Aluminium, Oak Sepia Wooden Trim, Extended Leather
Green Exclusive Dual Colour, Heated Comfort Leather Interior
Green Alcantara Headlining, Pillars, Rear Shelf, Door Inserts
Green Trimmed Mats, Seatbelts, Steering Wheel, Centre Armrests
DAB, Freeview, ACC, 4-Zone Climate, Soft Close, Electric Blinds
Old 14th May 2015, 09:52 PM
Hello MAM, long time no see mate
If you have VCDS then it is a 1 minute job, I've had the same issue and we were scratching out heads with Del, Manny and PsYcHe.
here is solution
http://forum.a8parts.co.uk/showthread.php?t=7651&page=5
I will actually try to make it a shorter, clearer thread from it this week and ask Architex to make it sticky as this happens quiet regularly to people.
Old 28th May 2015, 06:58 AM
Burnzybubbles's Avatar
As above I used M-A8's thread to get mine back when I'd upgraded to Bluetooth, worked brilliantly
Old 28th March 2016, 12:34 AM
H-M3 H-M3 is offline
sorry had to revive this thread. I want to upgrade the phone in my d3 to BT, currently has fixed motorola phone. Is it just plug n play or do i need new cables etc?
cheers
Old 29th March 2016, 08:53 AM
You'd need the 34-pin connector block if that didn't come with the module, but apart from that, the rest of the cables are there.
Old 29th March 2016, 04:36 PM
Cheers fella, any pic of this actual connector or part number.
Old 30th March 2016, 01:31 PM
4e0 972 144 is the connector block.
Old 30th March 2016, 02:46 PM
cheers Psyche.
Just for everyone reading this, can anybody list the part number we should look out for for the actual BT unit?
Old 30th March 2016, 08:57 PM
Somerandomguy's Avatar
Yes, its 4e0 862 335
Old 30th March 2016, 09:03 PM
