Thanks both for your assistance.
I have the 5A Ctek and charged it to 80% as I had to drive the car the next day. I'll remove it tonight to give it a full recondition charge. I've not checked the plenum drains since ive bought it but did clear the 2 wheel arch drain just after xmas. You could be onto something there as if there was any water in that area, it would drain towards the ECU etc the way i parked it. I may call the RAC out to do a load test on the battery. If all is well, will attempt the residual drain test. I've never known such a difficult battery to remove from a car, what a ridiculously sized compartment.
Shirish: 2001 S8 |
