So, do you think a carefully positioned full bottle of water resting on the seat switches could be the cause!?
Wondered why the seat position was so far off this morning...could barely get in the driving seat. Wonder also if the motor is now screwed .....
Shirish: 2001 S8 |
Naaah. Surely there is an "end of travel" micro-switch that will cut power to the motor when it reaches its end-stop?
Lee 2017 Nissan Leaf Tekna |
good shout, but kinda hoping there isnt and this is the root cause!
rac man here shortly, will hopefully get a load test on the battery and see whats what.
Shirish: 2001 S8 |
Just tested, motors stop at limit with buttons held down, but presumably there is still some drain from the control circuit. Should be minimal though.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
thanks for that, time to look elsewhere.
RAC man come and gone - suggest battery is ok, however a possible large drain detected. Unsure if this was because the car hadnt gone into sleep/shutdown mode when the test was started (how long does it take to go into shutdown mode?) Comments Suspected Diagnosis: battery flat - charging/starting system tested ok. advise 40min drive to charge and 24hr trickle charge to fully recover battery. no load drain above acceptable limit after 5mins, advise further investigation at garage asap. Battery Test Results Battery Test Battery Manufacturer: BOSCH Rating of battery tested: 720EN Chemistry of battery tested: FLOODED Rated Ah of battery tested: 90 Smart charge: No Battery Test Results Time: 02/04/2016 14:55 Temperature: 22.2°C Measured voltage: 2.61Volts Measured rating: 202EN State of health: 40% State of charge: 0% Test Result: Good Recharge System Test Jump pack used:Yes Starter Avg voltage: 8.03Volts Starter Avg current: 173.9Amps Starter result decision: Charge Battery Alternator voltage (unloaded): 14.02Volts Alternator voltage (loaded): 13.56Volts Alternator current (unloaded): 22.7Amps Alternator current (loaded): 17.2Amps Charge acceptance test performed: Yes Diode decision: Normal Alternator test decision: Normal First drain test voltage: 2.61Volts First drain test current: 0.1Amps Second drain test voltage: 12.06Volts Second drain test current: -0.9Amps
Shirish: 2001 S8 |
I've got pics of mine in a fairly heavily dismantled condition to access the battery! Boot side trim off and moved to the centre and trim by boot catch removed too
I didn't feel confident keeping everything out the way on reassembly without stripping it that far and it dropped in very easily. A helping pair of hands or HP's approach would be alternatives but getting it out single handed would be a struggle through that tiny hole
I'd suggest you check the state of the positve feed 'junction box' where the wire splits and feeds the alternator and starter motor. This is located on the O/S chassis leg as is a troublesome earth lead, which can also cause problems. I havn't got any photos of these parts, perhaps others can assist, but I know that just these two connections/wires can wreak havoc when they become corroded.
Pics of battery compartment access:
Note that tail light removal is not required! I happened to be in there doing that a couple of weeks before the battery died....
All looks very familiar. Pretty sure I swapped over OK without removing the side trim though, but it looks like it would make it a lot easier.
Battery undergoing a full recondition charge on the ctek - should be done later this afternoon, however unsure I'll get time to follow Dels procedure that he kindly uploaded.
Shirish: 2001 S8 |
