mine look exactly the same.
odd how they look so stone chipped. look forward to the write up. |
same here - what on earth causes this in the first place?
Lashing rain, stones, insects and just dirty air constantly wearing away at the coating on the leading edge and then corrosion takes a foothold....
Lee 2017 Nissan Leaf Tekna |
May sound silly but is there not an uprated version available? Even after market? Seems a big job to do to have it happen again potentially in 4 years.
We need carbon fibre replacements....
Has anybody spoken to any of the wrap companies, could you clean them up and then wrap in piano black wrap. Just a thought?
Was think of that option for mine, which are just the same. Best regards Seamaster |
To be honest, I just "colour them in" with a permanent black marker pen. It's only the very edge on mine at the moment, so not too bad. I'm guessing a wrap wouldn't stay on for long if it was still corroding underneath. You'd need to remove the loose corrosion first and paint with some sort of aluminium etch primer stuff before wrapping I think.
Im going the wrapping route when Ill be wrapping all of the car in 4 weeks time. Thinking of sanding it down a bit and just wrap it in iSee2 ultra black, its very glossy.
Please post pics of your wrap progress, I am interested in this
I had the same problem on my Passat - I just rubbed down the leading edge with wet and dry and flushed with IPA alcohol spray and then masked with tape tucked behind and over the rubber and then painted a line down the edge and behind it between the rubber and metal with one of those tiny pots of humbrol airfix paint and a small artist brush. The paint is satin black and a good match. I still have it somewhere just need to get some new art brushes and paint the D3's.
