Old 7th April 2016, 08:32 AM
Or is there a better easy to use at room temperature plastic for moulding?
http://www.maplin.co.uk/p/mindsets-polymorph-250g-n14at
Might melt again though if there's much heat in that area.
Or there's Sugru: https://sugru.com/
Old 8th April 2016, 03:53 PM
oldnick oldnick is offline
could anyone post a picture/dimensions of the early FL ones with the separate foglight surround ? are they handed ?
I have a cunning plan
Old 9th April 2016, 08:20 PM
Yes they are handed and in 4 pieces - 2 per side
The later 2001/2 type were larger 1 piece
Old 9th April 2016, 08:21 PM
Fog lamp piece
Old 9th April 2016, 08:22 PM
Rear of fog lamp piece
Old 5th May 2016, 06:06 PM
thanks very much ...been offline for a few weeks then forgot this until now !
Old 5th May 2016, 09:30 PM
Hmm interesting. Will those early fog light surrounds fit the later models? I also have a cunning plan...
Old 28th May 2016, 08:14 PM
funkmiester funkmiester is offline
I have a 3D printer, two holes in my bumper and a great deal of ambition. It's not the printing, it's the drawing that will be the task, but I'm going to have a go. Failures will be photographed as well. Prototypes will be in white as I have black ABS on order.
Old 28th May 2016, 08:23 PM
Instead of trying to draw it in 3d have you considered photogrammetry?
Old 29th May 2016, 12:32 PM
well that puts my idea in the shade [ clue ...my brother owns a dental laboratory ]
are you going to try the early 2 piece or the one piece ? I suspect the light surround for the 2 piece is easy to obtain , don't think they fell off
I presume the one piece can be used to replace the 2 piece
