So, Ive noticed that the rear drivers side corner drops a little overnight. After leaving the car for more than 48 hours, I think passengers side drops a bit too. Where do I start looking for this air leak? I have read about using soapy water, but will this help me find what seems to be a very small leak?
Also, few weeks ago I tried to calibrate suspension with no luck, after car is restarted it goes back to normal. Wonder if this has anything to do with this leak? Any help would be appreciated. |
And I thought I searched a lot before asking the question. Thanks! Will give it a go tomorrow hopefully.
If you skip to 11:18 in this video you can see how the charging of the axle is done and what to look at etc.
https://www.youtube.com/watch?v=OU5SBmHQIfI Just remember thats the front axle in the video ![]()
Del ![]() Last edited by Delboy; 8th April 2016 at 08:26 PM. |
Well I had a go today, but no luck finding it. Is there anywhere else I could look for it? The only thing that keeps bugging me is what if the leak is at other side of the air bag? Frustrating this
Have you had the arch liner passenger side and soaped up the valve block?
Del ![]() |
Wasn't aware of this valve block, I only did drivers side as thats where it drops overnight. Another job for tomorrow I guess. Is it easy to get to?
Yeah it's not too bad, whip the front wheel off the remove or peel open the rear half of the liner, the valve block is up in the corner near the bulkhead
The thing at the edge of this picture with the different coloured lines is what you need to spray on.
Del ![]() Last edited by Delboy; 9th April 2016 at 10:05 PM. |
Thanks, I don't think Ill manage to do that today, will have to be next Saturday job.
