Old 22nd April 2016, 09:28 AM
krazy_ivan's Avatar
krazy_ivan krazy_ivan is offline
Press the 'Car' button and it will be displayed on the MMI screen.
thanks!
test
Old 24th April 2016, 10:29 PM
krazy_ivan's Avatar
so, i have a sport suspension (is that good or bad?)
i ran the number s on will they fit
on car documents says , on registration it came with 235/50 r18 101Y`(i suspect and 8J)
i ran numbers for an 10.5 wide rim, 20" and an ET of 27 ( http://www.nicheroadwheels.com/specs.cfm?id=5093 )
says 1% difference in circumference (ok i think) but im worried over the rim moving in closer by 1.5 cm )
Compared to your existing wheel, this new wheel will have an inner rim which is 15.8mm closer to the suspension strut. The outer rim will poke out 47.8mm more than before.
will this work??? i mean, without spacers
please let me know if you do
test
Old 25th April 2016, 12:32 PM
You will need to get your car up onto a ramp or get underneath and see how close the existing wheels are to everything and then add those figures on to the inside and outside of the wheel and see if it looks like you will have clearance - its the only way to tell without actually offering up the actual wheels and tyres
Old 25th April 2016, 01:32 PM
krazy_ivan's Avatar
mm, not really my cup of tea
luckily for me, i need to put the car in a serviceshop soon, change the filters, oil etc everything.
ill ask them to measure it for me.
even if they would come in to close, it could still be sorted out with a spacer as a last resort i guess
test
Old 5th February 2019, 09:56 PM
H-M3 H-M3 is offline
Hi mate old thread but did you actually put wide rims on your 8?
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
