Old 25th April 2016, 06:33 AM
Access is all on the passenger side - the coolant pipes going through the bulkhead get in the way, but it's only 2 screws to remove a cover, then another 2 screws to remove the motor. Just make sure the rubber gasket is re-seated correctly
Taking the lid off the airbox means you can manually move the flaps to get the motor drive engaged without any hassle.
