Suspension calibration on D3
Hi Colin,
I had problems doing mine. The technique with VCDS is very specific and is on the VCDS wiki.
Open controller, select channel 1, allow it to go down then up until it reads something like ready. Then put in value as measured. Press test then SAVE. Move to channel 2 and repeat including save. When all 4 wheels done, you need to put value (1 from memory) into channel 5, test then SAVE again. Only then will light go out and may need fault to be cleared.
You cannot miss any wheel and have to follow the sequence from channel 1 to channel 5.
I was missing out the save, worked for first 2 wheels, but gave invalid on channel 3 or 4 and light would not go off. I put standard values in first to prove it was all ok, before then redoing measurements second time around.
Good luck
Richard
2006 Audi S8 V10 Now Sold.  Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
