D4 - Transmission Gearboxes, diffs, drive shafts. |
a little update
after a few days the warning light came back on im afraid and the original fault code was still there with this in mind i decided to change the second pressure temp sensor (brown plug) got my car up in the air and quickly discovered that unless you have a very very thin walled deep socket , you will not get this sensor off the car i then had a friend who is a very very good machinist mill my own 27mm deep socket down so as the wall is only 0.5mm thick took a couple of hours to set up and machine but it was worth it as i have now finally been able to swap the second sensor after this has been done you need to go into settings and transfer the oil and temp sensor settings from vcds then unplug vcds for 2 minutes reconnect and go into security section input security code and go into output tests fill lines bleed lines pressure test i can also now confirm the original information from the audi dealer is incorrect there are two different types of oil in the sports diff one is for the actual gear diff fluid the other is hydraulic atf fluid (G060 162 a2) looking from the back of the car the atf inspection is on the left hand side of the diff looking from the back of the car the diff oil inspection is on the right hand side of the diff Last edited by nath; 8th June 2016 at 04:37 AM. |
