Old 17th June 2016, 03:56 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Thanks again to ainarssems. My screws arrived and I fitted about 7 of them today. A few of the retaining clips had corroded and I used nuts and bolts in their place, given that I use an oil vacuum to change the oil it's no concern. The undertray is going nowhere!
My advice to others would be get more than you need, also buy the retaining clips too.
All the best.
John.
2007 Mini Cooper S R56
Old 7th July 2017, 12:40 AM
H-M3 H-M3 is offline
Default bump
need to order some, how are your clips surviving?
cheers
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 7th July 2017, 06:50 AM
Johnmed's Avatar
The screws are fine, but my retaining clips were past their best. I used nuts and bolts more than the clips. I use an oil pump so don't need access to the sump regularly.
In retrospect I would order clips and screws.
Old 7th July 2017, 08:05 AM
Thanks. Would you recommend the Fleabay ones?
Old 7th July 2017, 08:43 AM
Johnmed's Avatar
The screws I got were perfect. I'd just advise you renew your clips, as they rust away.
Old 7th July 2017, 03:49 PM
Turbo Tony's Avatar
I hate those things - they keep working their way loose on mine.
Storytellers Villa Orlando
2008 Audi S8
Old 7th July 2017, 04:05 PM
Johnmed's Avatar
They are hateful things. I've seen the undertray hanging low enough times to just bolt the thing in.
Old 5th September 2017, 07:39 AM
lackovicj lackovicj is offline
Exactly...Fitted new one a few days later noticed 2 bolts are missing already.
