D4 - Axles, Brakes, Suspension and Steering Brakes, Springs, shocks, steering racks, steering columns, suspension arms, wheel hubs etc. |
I've recently done the rear pads and discs on my D4. The Pagid ones at ECP fitted with no problems and are performing well. New wear sensors are included with the new pads. Just to confirm on my 3.0 TFSI, there are wear sensors on the rears too. Just on one side though.
Any feedback on brake dust from the pagid or brembo options ?
Genuine pads seem to be mostly made by Ferodo by the way. |
Did you do that yourself - any feedback on how difficult it was. I have plenty of experience changing pads and discs on older cars and wondering whether I can do discs and pads all round myself rather than paying the stealer (£1600 ![]() ![]() |
Yeah I did them myself. I've only done the rears though. I think they're trickier than the front. It's just the same as on any vehicle except you need VCDS or a generic code reading unit to allow you to wind back the callipers. Once the callipers are wound back, you release and remove the sliding pins, remove the caliper and then wind back the callipers with a wind back tool.
Remove the calliper carrier and disc then refit all. You don't need any special tools just the usual tools you'd need for any brake change. |
Nice one - thanks very much. Appreciate the info - sounds like I now have an excellent excuse to buy a VCDS as well as saving some money on the brakes!
i ordered set for front and back, pagid pads, all together(front +back) with promotion code and delivery came to £90 from ECP
Audi A8 D4 4H 2012 3.0tdi Quattro 8spd ZF 8HP55a |
I used a generic OBD tool to wind back the pistons and then wound them back on again once I'd finished. I know that VCDS asks you to enter the new pad mm thickness but I wasn't asked with the tool I used.
Do a search on youtube on guides to change rear pads on later Audi models. I think C7 A6's have the same procedure. |
update on whole procedure.
i have changed front and rear. front: no issues, just to remember wear sensors are not icluded in set, luckily mine sensors were ok, you can buy them seperate for cost of around £8. changing procedure as any other braking system, release 2 caliper nuts and one on outer side of caliper. caliper will come off, change pads and put everything back together. rear: release parking brake - in vcds, controller 53(parking brake) -my controller is working in UDS protocol - so go to basic settings - from drop down list choose 'start linning change procedure' - you will hear parking brake winding all way back and screen shows 'running' - once screen shows 'not running' - go out from controller- close vcds - turn off ignition - you will notice parking brake button and 'P' on dash will flash - also don't worry if during changing process both lights stop flashing, it is energy saving feature. - next thing changing pads - well piece of cake ![]() one thing - i forgot about brake fluid so when i push pistons back brake fluid came out through tank lid and went through drainage on driveway. as fluid is corrosive i used luke warm water with fairy liquid and washed tank and flushed drainage. second thing - i didnt hook up battery charger for whole procedure but I advise you to do it. i took us 40 minutes to do front and rear.
Pad warning light came on so sent car to get front pads replaced ,when she came back with the new pads light still on ,sent her back and mechanic says sensors ok and it has to be a broken wire somewhere ,not a big job to fix if you could find the break ,does anybody know if I can disable the pad warning light with Ross Tec and if so does anybody know how please
( d4 car) Thanks
With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
