Old 27th June 2016, 07:37 PM
Burnzybubbles's Avatar
What colour? Would help determine what could be wrong with it, leaky injectors is usually white smoke, has it had a full service and filters replaced? Have you checked the condition of the egr valve and inlet system?
Old 28th June 2016, 05:36 AM
Artermis Artermis is offline
Sorry guys - black smoke, not white.
I've not checked EGR setup, no. I'm not familiar with the EGR setup on these motors so I don't rightly know what to look for. Any diagrams or pointers?
Current: 2004 D3 4.0 TDI V8 in Crystal Blue.
Factory: finger print, tv, xenons, keyless entry & go, soft close boot, 19s, and probably lots more besides
Done: fixed headlight washer leak, fit Bluetooth in place of factory phone
To do: DAB, DTV, fix soft close boot, get a spare key, investigate NSF bushes,
Old 28th June 2016, 11:31 AM
Joe2.0E Joe2.0E is offline
Black Smoke could indicate issues with the Turbo but if its passing an MOT and mpg is okay, I would ignore it unless you want to throw money at it.
Has it got big mileage ?
Old 28th June 2016, 06:06 PM
Nah it's only on 125k, not a lot really.
I'm tempted to get it on a ramp at weekend and check for boost leaks (i.e. loss of charged air making it go rich) and blank the EGRs off to see if that makes a difference. I must have a bit of cake tin or something somewhere to make a couple of blanks up with; unless they're visibly caked up and not functioning properly in which case I'll clean and restore.
I just don't know if it will throw a metered air or air quality code up; later cars I know certainly will but I don't think cars this early should care - if memory serves it's only about euro 4 on that it got clamped down on.
