I did
![]() Do yours not work at all with the doors closed? It sets the memory when you open the door.. I guess it's that you may be in and out the boot a couple of times, so saves power on the system by not doing the move until you open the door.
If you are out the car ie it 'sees' the door open then it will one touch the seat to the saved position.
With the door shut then you could press the wrong button and become impaled on the steering wheel if you chose a midget's position by mistake so it needs the button continuously pressed. Audi think from all angles! |
