Old 12th July 2016, 07:32 PM
Pellesin Pellesin is offline
Originally Posted by CamSteel View Post
It does not matter which side of the caliper you can see the leak from, you need to get that caliper changed, I had to the same thing a month ago and got a exchange unit from fleabay at £175 with a surcharge of £75 for the old one, you should also factor in that you will need someone with the VagCom or similar for the windback on the electronic handbrake.
I did the windback with my own vagcom. Really straight forward. But thanx for the reminder.
I did the isolation procedure to find out where to get the seal set from the "gold smith" (nick name for the local Audi dealer. Same weight to price ratio - hence the name) or from e-bay. Gold smith didn't supply the seal for the input shaft/axle. I'd go for the other if it was the forward side(piston) that leaked. This not being the case I was "forced" to wait for the parts from the UK.
Does anyone know wether the refurbished ones have a new input shaft/axle?
I'll make sure to "confess" when the caliper starts leaking again so that others can learn aswell. (it's not a if but a when)
I hope it will hold up until spring next year - that will buy me some time to figure out a fix that will last a bit longer...
