Well I had another bash this afternoon and still getting nowhere.
I managed to get all the old remains of the now broken light from behind the screw, so the screw head is now in thin air. Then I got a good pair of pliers, got hold of the screw head and tried to turn it. The result was the same, nothing budged its still stuck. On the D3 its not a self tapping screw, but a fine thread standard philips screw. I tried pulling on to see if I could overcome the threads, that does not work either. I don't know whats on the car side of that screw but its obviously not plastic. The screw kind of pivots on the opposite end to the head if put a screwdriver down the side. Drill it out now is going to be a right pain, as once the head goes there is still 3-5mm of threaded part to deal with. I may end up getting rid of the screw head, applying something onto the back of the new holder and using a single screw to hold it in place. One screw holds the broken one ok, but there is a small amount of movement on the other side.
