D3 - Common Faults Quick links to all known common faults and their solutions |
When under the car just look straight up where the downpipe connects to the flexi pipe on the exhaust. Had to use a light and did some searching before i found them.
Mine was "glued" shut due to all the gunk so no water went through. I sure wonder if there would be any wrong in removing those cowl drains fully? Then there will be no problem with water and gunk clogging the drains. I have no photos of this, I'm sorry. ![]() I guess the only chance to attach the clip is to remove the whole AC housing, but not sure how to do that. Regards Kenneth |
You don't want to know 😱
You be better buying a new car Quote:
Del ![]() |
Thats just great..
Maybe if i remove the exhaust and gearbox ![]() |
Great thread this, lots of good information
![]() I drove out in my 8 on Tuesday night and heard a "sloshing" noise but wasn't sure where it was coming from. Music off, drove some more, decided it was from above rather than below me. I decided to have a look at the weekend as time after work is limited, as is daylight right now. Drove out last night and first right turn saw copious amounts of water cascade from the headlining near the C pillar and drench the seat ![]() ![]() Scuttle panels removed afterwards and cleaned and flushed so hopefully I've caught this before any real damage is done. I really can't emphasise enough the views of others that these need to be cleaned regularly, I feel like I've had a lucky escape this week.
Audi D3 S8 - 2007 - V10. B&O, Phantom Black, black and silver interior, and still completely standard with everything working as it should ![]() ![]() Audi TT - 2015 - Ultra |
Glad you caught it Ron. Reminds me mine should get another look soon. Will have to wait as off to Canada in the morning.
Del ![]() |
I use an adapted Garden sprayer for the front sunroof drains. The rears I did last year by removing the back wheels and arch liners, although they were ok.
I've never done the Scuttle drains yet, I make a point of regularly removing the scuttle covers and going over the whole area with a vacuum to stop the crud getting down to the bottom.
I used a bug spray bottle similar to Del's, did the trick for me. It allows a decent flow of hot soapy water to be directed down the drains to ensure they're clear. I haven't done the rears but I'm not too concerned. My cars stands facing down a slightly inclined drive so my assumption is that the dirt will always be exiting the sunroof area via the front drains, so they're most likely to block.
I removed the scuttle covers, saw there wasn't much debris at all, removed what was there, then flushed water through them and observed it exiting rapidly from both sides so I'm happy they're good for now ![]()
