Old 20th July 2016, 04:04 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Default Nearside wing mirror - odd behaviour
The passenger wing mirror on my 2002 S8 has been acting up lately.
If I'm reversing with the control switch to the left, the dipped function seems to work OK but then it doesn't quite want to return back to the normal position.
Any ideas what cause this guys?
Old 26th July 2016, 09:49 AM
RICKY D's Avatar
Anyone?
Old 26th July 2016, 10:12 AM
Mine used to do just that, until I changed the ally housings (it's an S8). I'm sure that the housings had nothing to do with it, but it was pretty mucky behind the mirror where all the moving parts are, so I cleaned it up a bit and gave them a squirt of WD40. I wonder if it was simply a bit of muck or lack of lubrication?
It's pretty easy to pop out the mirrors and have a look.
Old 26th July 2016, 10:20 AM
Similar experiences, way back.
Getting lubrication inside isn't easy, IIRC I actually took my mirror off to swap it (for a spare purchased from our sponsors) and found that once unmounted and upside down there was a good route in for WD40, which fixed it!
Old 27th July 2016, 01:44 PM
RICKY D's Avatar
Thanks for tips guys.
I just replaced the glass on both sides and gave them a good clean but didn't think to "throw" some lube in there as well.
I should be off work tomorrow so might be a job for then.....I'll update accordingly!
Rich
Old 27th July 2016, 01:58 PM
See here, I knew I'd documented it: http://forum.a8parts.co.uk/showthread.php?t=5047
Old 29th July 2016, 09:34 AM
RICKY D's Avatar
Top man!
If I get some time this weekend this looks like a nice job to tackle!
Old 16th February 2018, 09:51 AM
RICKY D's Avatar
Just a quick update regarding this as I managed to resolve this issue a while back.
Following the advice from The Laird and HP I removed the glass and applied WD40 liberally. After engaging reverse several times I noticed it was very slowly starting to return to its normally position after moving out of neutral. More WD40 and more reversing and it was soon moving freely like it should do.
I remember when I bought the car the wing mirror knob position was centred so I wonder if the lack of use meant that it just seized up over the years. It’s been well over a year and still working fine.
Old 16th February 2018, 10:23 AM
And I was "having a go" at a job that took a year, this is nearly 2 .....
Glad it's sorted though, another "cheap fix".
