Old 10th September 2016, 08:32 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Split cv boot flicking grease on to exhaust?
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 11th September 2016, 11:42 AM
oldnick oldnick is offline
3.7 40v FL 2000
thanks guys , sounds like maybe something on the exhaust
more work
Old 11th September 2016, 12:47 PM
Turbo Tony's Avatar
Could be something as simples as a plastic bag/tar spot got caught on the catalyst and burning off.
...Yes, I'm ever the optimist!
Storytellers Villa Orlando
2008 Audi S8
Old 11th September 2016, 06:48 PM
Is this not a symptom of the rear output shaft seal?
I agree David - could well be the rear gearbox output shaft seal which when it leaks fluid gets discharged onto the exhaust and creates a very unique smell
Originally Posted by oldnick View Post
3.7 40v FL 2000
more work
Check out previous threads on the above
Old 11th September 2016, 07:19 PM
Over the years I've had that stink many many times. Always been a leaking seal for one of the shafts (rear output or either front wheel).
Old 12th September 2016, 08:45 AM
thanks for the addition of the front wheel seals andrew
before I get out and get under do you happen do know if that is an easy fix ?
or the part number ?
what makes the burning smell on a front wheel shaft ?
I don't fancy the rear output shaft job so which job do I hope it is , lol ...it is certainly looking to be one or the other judging by the frequency of the problem of shaft seal failures !
ps proximity sensors yet to be located ...busy, busy ..that's retirement
Old 12th September 2016, 09:15 AM
Diff oil (standard gear oil) can leak out of the front shafts, and if it leaks enough can blow back on to the downpipes.
I did these on mine a while ago and meant to make a thread on it. I'll stick one together later with part numbers
Old 12th September 2016, 09:17 AM
Lubricant dripping onto the catalysts/exhaust is what makes the stink.
No idea how easy it is as a DIY job I've always had it done by a garage. Never said it was difficult though.
Old 12th September 2016, 09:27 AM
Definitely DIYable if you have a decent bench vice. The hardest part is getting the driveshafts out tbh, because you have to pull a lower control arm.
