Old 1st October 2016, 08:37 AM
01273 code and fan always on at full speed is most likely because blower controller/resistor pack is faulty.
Other 2 codes because FL AC unit uses CANBUS for communications with the rest of car but PF car does not have CANBUS and uses K-line + separate signal wires. So you would need to fit CAN gateway that will translate signals.
