Old 13th October 2016, 09:59 AM
Zip's Avatar
Zip Zip is offline
Question Intermittent rumbling & slight vibration from rear at speed
At 70+ motorway speeds, I am getting on frequent occasions a rumbling and vibration from the rear of the car that can build for a couple of miles or so, and then can fade away never to be felt or heard again on the journey. Any ideas? Diff? Wheel bearings? I'm on modest spacers at the back if you think that has anything to do with it, but I'm not convinced. Are there any other wear items back there. Mentioned it at my last service, but they couldn't replicat it.
Thanks,
Zip
Old 13th October 2016, 10:29 AM
Thanks,
Zip
I'd go with either wheel bearings or the infamous sticking rear handbrake cable / release which if you dont use the car much is a possiblity
Old 13th October 2016, 12:27 PM
Bearings would be a common one for that.
I'd be tempted to jack each of the rear wheels up in and turn and check it for rotation / play etc.
Old 13th October 2016, 01:54 PM
I had a similar issue a while ago. Intermittent vibration/rumble. Never quite worked out the pattern to it but usually started after a bit of enthusiastic acceleration on the motorway. Seemed to go away after 10 mins or so of gentler driving.
If I remember correctly, I had the wheels rebalanced and a proper (4-wheel) alignment done. Seemed to cure it.
Old 13th October 2016, 03:30 PM
Had similar symptoms last year and it was a sticking calliper
Old 13th October 2016, 03:44 PM
I was racking my brains what the cure was in my case. I was struggling to remember because I had a few different jobs done on the car at the time, full wheel alignment being one of them. But you're right, I also had a sticking rear caliper changed at the time. I remember now, that was it!
Old 13th October 2016, 10:41 PM
Zip's Avatar
Zip Zip is offline
Hmmm...maybe my calipers are playing up. But the pattern is the same....up to speed on motorway, a few miles of rumble, then fading away. Can get pretty intrusive. I'll check wheel play again.
If you recall what any other solution was, please let me know.
Thanks,
Zip
Old 16th October 2016, 11:14 AM
What make of tyres are on it ?
Does sound like sticking calipers but have heard weird noises off tyres that can come and go , maybe worth swapping wheels around to see if noise transfers
Old 16th October 2016, 09:46 PM
Pug Pug is offline
And as another suggestion, what are your tread depths all round?
Current: MY2019.5 Ford Ranger Wildtrak 2.0 BiTurbo
A8/S8 - A gap to fill.
Multi-Franchise Main Dealer during the day, Amateur vehicle enthusiast by night.
Old 17th October 2016, 11:13 AM
Zip's Avatar
Zip Zip is offline
Tyres all good....MPSSs all round
