Old 14th October 2016, 09:47 AM
You can just see a bit of that central rib behind the camera; I had to cut some of that away additionally at an angle to clear both the cable exit and front of the camera (and to make putting it on easier).
And as you can see my fitting symmetry wasn't perfect, though I'm not convinced the car is either....
Old 14th October 2016, 02:00 PM
Nice and makes sense.
I'd suggest to order A4 marine stainless steel screws from eBay to make sure they won't rust in that area.
Old 21st October 2016, 10:02 AM
The fixing bolts aren't into the bodywork, they go into what look like brass nuts embedded in the rubber well nuts so there's no contact at all with the metal of the boot lid.
Nonetheless I'll check them after a while and see if there's any corrosion and take "appropriate action".
