Old 19th October 2016, 05:54 PM
Sir WIll Sir WIll is offline
Default A few winter jobs on the old girl
Well the MOT is done and the old girl has been serviced again for another year by the local specialist.
A couple of small jobs need doing that I want to do to keep the car perfect.
The Cam Cover gaskets are pretty good but one is getting a little weepy so I am going to replace both of them to ensure everything is perfect.
077 198 025 seems to be the right part for a FL 4.2, apart from eBay where is the best price/ place people have found them for?
Old 20th October 2016, 10:17 AM
27litres's Avatar
27litres 27litres is offline
Genuine through Easy-Square
After market through FCP Euro (Victor Reinz)
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 20th October 2016, 08:04 PM
Thank you kind sir
Old 20th October 2016, 09:18 PM
YorkshireBloke's Avatar
Default Weepy?
Hi,
I have a very slight engine oil weep tfrom the top of my 3.7: is that the kind of "weepy" here?
Mine is a running leak from the top end, 30 ml at a time...
Robert
Old 20th October 2016, 09:37 PM
Now its been a few years since I replaced one but it should be straight forward enough.
Is the current wisdom to use a little sealant on one or both or the surfaces or just rely on cleaning it all and purely the new gasket?
Regards.
Old 22nd October 2016, 01:41 AM
27litres's Avatar
The rubber gasket itself will seal Ok when torqued down, but I think a dab of sealant on the sharp corners is what guys usually do - I don't recall what I did to mine a couple of years back... I seem to recall mention of sealing the half moon seals if they're used too (mine didn't use those).
I can't recall what I did to secure the rings for the spark plugs if anything.
Marty
Family:
Sold:
1997 Audi A4
Old 22nd October 2016, 06:28 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
The engine workshop manual is in here
http://forum.a8parts.co.uk/showthread.php?t=9345
Full write up in removing and replacing rocker cover gaskets and where to put sealant.
My rebulid 'kit' came with 2 ebay gasket sets. Included the half moon seals, centre bolt seals and spark plug holder seals.
Pretty straight forward fit and not a drop of oil leaked do far
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 22nd October 2016, 11:04 PM
Perfect, thank you chaps
Section saved and printed out ready for a little work on the old girl over an upcoming weekend.
