Old 26th October 2016, 04:44 PM
Wires will be for heating elements in the nozzles.
Sounds like the passenger nozzle is still blocked... More needlework required
Old 27th October 2016, 08:54 AM
oldnick oldnick is offline
tks ian , all fixed , unfortunately needlework wouldn't do it because what was blocking the jets was a gel like consistency and the needle just stirred it
however went next door , detached the end , put a fine jet fitting on the airline and 8 bar pressure gradually cleared it by blowing to and fro, even then had to use the washers to clear the last bit out
now to get the headlamp washers working , probably just the filter , not needed for the MOT as I understand it so can wait
Old 27th October 2016, 10:03 AM
Result
Old 28th October 2016, 09:12 AM
The "snot" like substance is bacterial build up and it is possible that it contains Legionella bacteria so just be careful when blowing it about with an air-line! It will grow in the spray heads particularly because they are heated and bacteria just LOVE the warm conditions which is why they grow in cooling towers and air con units.
