Old 3rd November 2016, 09:32 PM
aTOMic's Avatar
aTOMic aTOMic is offline
Seems I remember boiling in simple H2O will cause a surface layer of aluminum oxide to form - a very durable substance. Only trouble is it's a matte gray finish AFAIK.
Yes in the US I bought some "Air Conditioner Coil Cleaner" liquid which turns out is simply a strong sodium hydroxide (lye) and water solution. It foamed up madly and removed 40 years' worth of dirt from my evaporator and condenser coils on the home HVAC, and shined up my dear departed Granma's espresso (moka) pot. Can't one buy lye drain opener in the UK?
Haven't experimented much with it as it requires full protective gear which is HOT and cumbersome in the Tennessee heat... and I actually heed warnings to the point of buying a $90 respirator w/ organic vapor filter for this job. Along with industrial rubber sleeve gloves, face shield, etc.. Having worked on an ambulance here in "Hey man, hold my beer and watch this!" country, I've seen some things...
I'm in love with a car.
2004 4.2L Petrol A8L
Sage Green/Black (one of only five D3s thus colored sold in the US)
Old 4th November 2016, 01:23 PM
Yes you can get Sodium Hydroxide drain cleaner here. some have recommended it for cleaning the drains in the scuttle (probably called something different in USA ) but I am not sure I want it near paintwork even under the bonnet(hood) as is (obviously) caustic. By the way, how did the coffee taste?
Old 4th November 2016, 01:45 PM
Aluminium and Caustic soda is a VERY VERY BAD IDEA! https://www.youtube.com/watch?v=FdRrZH3M5O0
Old 4th November 2016, 02:05 PM
But look at how CLEAN it is!!
That could be your body work.........
Old 5th November 2016, 06:21 PM
aTOMic's Avatar
Coffee was fine; in fact the reason I researched how to treat the "raw" aluminum (aluminium* to you guys) was prevent any metallic taste - before I cleaned the 100-year-old pot, which had a layer of mineral buildup in the bottom (remember a moka pot boils dry each time)nothing would (chemicallly) touch.
I don't know what the US equivalent of "scuttle" is ("Sump?) however I do know what the word means, but I know VWs and Audis have a definite problem with their (scuttle) drainage!
*My wife is from Germany, moved to the US when she was 13; when I met her 20-odd years ago, she could not say the Al word either way; especially funny since she has two Masters' degrees - and one is biology! (A good old science joke here is to have someone say "aluminum" ten times as though it were a tongue-twister, then ask them what a tin can is made of)...
You are correct, sir; as I said...
...it requires full protective gear... ...and I actually heed warnings to the point of buying a $90 respirator w/ organic vapor filter for this job. Along with industrial rubber sleeve gloves, face shield, etc.. ...
In any case I have misunderstood the question - OP is talking about the plastic strips, and I was thinking of the removable window trim that is worn-looking on so many of our cars. I have always wondered how they chrome-plate plastic (assuming they do). There was an episode of "How It's Made" (Canadian TV series) which detailed the process IIRC.
Last edited by aTOMic; 5th November 2016 at 08:04 PM. Reason: Grammar, info added, clarity, etc.. OK?
Tags
chrome, discoloured, oxidised, plastic, tarnished
