Old 6th November 2016, 07:30 AM
Thats what I thought ^ Neither Mike's copy or mine have files for the AHC, AEW or ABZ Both have updated recently, but there's nothing in older or oldest either, or in a fresh install of VCDS lite on another PC.
The ECU number is 4D0 997 557 or 4D0 907 557. I think thats the same for all 32V, just with different suffixes for different versions. The label file should be 4D0-997-557.lbl I think (or 4D0-907-557.lbl) but there is nothing even close.
Surely they aren't retiring old files and removing them?
Old 6th November 2016, 09:07 AM
It is deffo ABZ
Is it still missing? Was fine when parked up so I can't see it being given much, I thought it would clear as she warmed up. Plugs are not that old.
Old 6th November 2016, 09:13 AM
It is deffo ABZ
What sort of warranty did you give Dezzy? ...and hadnt you better amend your signature
Old 6th November 2016, 10:17 AM
Thanks David, you're right I do need to update my sig. The 8 however needs no warranty it's bullet proof. Sold as seen well not even, the new owner was foaming at the mouth saying something like if only he could get his S to look as good.
Old 6th November 2016, 10:55 AM
077-907-557-ABZ.LBL,4D0-907-558-K ; ABZ (4D) Thats from the redirect info but of course the files not there.
I cant imagine there is much differences between that engine and the others like i mentioned.
It's quite easy to modify another label file and leave in your user folder once you have made sure the blocks actually match up.
I modified all three w12 lbl files to fit the V10 the ECU's.
I you want some help just give me a shout.
Old 6th November 2016, 11:03 AM
You sure its ABZ, VAS-PC has no ABZ listed for any era of A8
Old 6th November 2016, 12:29 PM
Just checked on my AHC and it shows' Label file: REDIR FAIL' and cannot find label file related to ECU but it still shows values as it should.
Old 6th November 2016, 05:39 PM
Red face
100%
I'm assuming the miss continues after reset with vcds. If it wasn't throwing pas fluid out as quick as I could put it in I'd have given it a good run.
Could be stale fuel anars, should be able to smell that from the filler, and prolly over half a tank of it in there. Not 3 years old though maybe 2.
WD40 will be your friend for sure.
I couldn't kill it by using it I'm sure it's not dead buy parking it up. She's a trojan I tell you
