  #38
Old 10th November 2016, 04:05 AM
Somerandomguy's Avatar
When I installed mine, I connected the TV to the DAB amp to check it was working- with the TV modules open in VCDS the screen displays various diagnostic information, including signal strength per antenna. (Using the Dab lead as'it had a universal connector)
Depending on which FAKRA cable you have on the DAB lead, you could try this too to rule out a failed amp? Obviously it wont be tuned to the corrct frequency, but would be interesting to see if any of the other amps improve reception.
Mine too drops out places, but I don't have another DAB to compare to
