Old 11th November 2016, 10:55 AM
ulfilias ulfilias is offline
Oodoom - Suspension height is quite complex, though in theory i can't see why it couldn't be done. You'd have to work through the ross tech stuff and use the code numbers documenting the proceedure etc as there isn't an "easy" follow through thing on the odb11 but I believe it's fully functional in what it does, so you can code anything in theory....Personally having done it, i'd be tempted with a hard coded ~£50 vagcom lead (you can only use the version of software it came with and upgrading kills the lead and it's a dodgy / risky (as in no support etc))....Or the full version!
