D4 - Axles, Brakes, Suspension and Steering Brakes, Springs, shocks, steering racks, steering columns, suspension arms, wheel hubs etc. |
Well, this car is now officially getting on my nerves.
As you may have seen, since i bought her, i've had the suspension compressor & accumulator done, then just done the electric coolant pump recently. Driving along today, i caught the rear right wheel on the kerb at an awkward junction, it climbed the kerb then dropped. Within 10 minutes or so, the ESP light came on, followed by the air suspension light. Immediately i thought the compressor had failed...again, but upon inspection the car hasn't lost level. I can raise the car, then lower it back no problem. The fault clears when i turn the ignition off then restart. But she drives poorly as soon as the ESP light comes on (rough feeling ride). -------------------------------------------------------------------------------- Chassis Type: 4H (4H0) Scan: 01 02 03 05 06 08 09 10 15 16 17 19 30 34 36 3B 42 46 52 53 55 56 5F 62 69 6C 6D 6F 72 81 8F 90 VIN: WAUZZZ4H Mileage: 175759km-109211miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 30-Special Function II -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Malfunction 0010 3B-Sensor Elect. -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 6F-Centr. Conv. II -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 81-Gear Shift -- Status: OK 0000 8F-Pretens. Frt Left -- Status: Malfunction 0010 90-Pretens. Frt Right -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (J623-CDTA) Labels: 059-907-401-V2.clb Part No SW: 4H0 907 401 HW: 4G0 907 401 Component: 3.0TDI EDC17 H37 0004 Revision: 53H37--- Coding: 0A2A4012052601020800 Shop #: WSC 02311 785 00200 ASAM Dataset: EV_ECM30TDI0114H0907401 001010 ROD: EV_ECM30TDI0114H0907401.rod VCID: 61D0B5F72149538A70AEFB9-8034 2 Faults Found: 4698 - Function Restriction due to Faults in Other Modules U1113 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Mileage: 175709 km Date: 2016.11.27 Time: 13:55:36 4699 - Function Restriction due to Faults in Other Modules U1113 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Mileage: 175709 km Date: 2016.11.27 Time: 13:55:36 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb Part No SW: 4H1 927 158 AA HW: 0BK 927 156 L Component: 0BK 30 TDIRdW H08 0002 Revision: --H08--- Coding: 001111 Shop #: WSC 02311 785 00200 ASAM Dataset: EV_TCMALX51011 001013 ROD: EV_TCMALX51011_AU64.rod VCID: 6FF4C3CFE79DF5FAF63A1D1-803A No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb Part No SW: 4H0 907 379 B HW: 4H0 907 379 B Component: ESP PREMIUM H10 0273 Revision: -------- Serial number: -------------- Coding: 60E5A30006A7C500E300 Shop #: WSC 02312 785 00200 ASAM Dataset: EV_ESPPremi 005006 ROD: EV_ESPPremi_AU64.rod VCID: 317005B73129A30AA08ECB9-8064 1 Fault Found: 0137 - Function Restriction due to Faults in Other Modules U1113 00 [136] - - MIL ON - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 13 Mileage: 175709 km Date: 2016.11.27 Time: 13:55:36 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 4H0 907 064 BB HW: 4H0 907 064 AB Component: BCM2 2.0 H23 0333 Revision: 00002001 Coding: 05B72F00000000000000 Shop #: WSC 00505 210 91477 VCID: 6AC2D2DBDC7F1052A14444D-803E Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B Component: J764 ELV MLB H38 0044 No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass (J521) Labels: None Part No SW: 4H0 959 760 F HW: 4H0 959 760 F Component: MEM-BFS H08 0153 Revision: AA000000 Serial number: 00001002231900 Coding: 0038320000047201000001010101102130313131282020 Shop #: WSC 02313 785 00200 VCID: 367A36ABD84784B2F57C80D-8062 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 4H0-820-043.clb Part No SW: 4H0 820 043 D HW: 4H0 820 043 D Component: Klima 3 Zonen H14 0061 Coding: 3621002800 Shop #: WSC 02313 785 00200 ASAM Dataset: EV_AirCondiFront 001050 ROD: EV_AirCondiFront_AU64.rod VCID: 2150F5F761C9138A302EBB9-8074 1 Fault Found: 0130 - Motor for Left Side Window Defrost Flap B10D7 21 [008] - Signal Amplitude Too Low Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 10 Mileage: 175489 km Date: 2016.11.21 Time: 14:45:11 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb Part No SW: 4H0 907 063 L HW: 4H0 907 063 D Component: BCM1 2.0 H12 0092 Revision: 15012002 Serial number: 00000000741397 Coding: 26002010C034AFE18B810007A0001D0C009DC30A0701010180 0008402000 Shop #: WSC 02313 785 00200 VCID: 317005B73129A38AA08ECB9-8064 Subsystem 1 - Part No SW: 4H2 955 119 C HW: 4H2 955 119 A Labels: 1KX-955-119.CLB Component: WWS641 100708 H32 0040 Coding: 0045F7 Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB Component: RLS H04 0003 Coding: 025523 Subsystem 3 - Part No SW: 4H0 941 531 HW: 4H0 941 531 Component: E1 - LDS H07 0044 Subsystem 4 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C Component: EVLS-SG H08 0280 Coding: 020300 Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H02 0002 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb Part No SW: 4H0 919 475 H HW: 4H0 919 475 C Component: PARKHILFE ACC H07 0030 Revision: 11001001 Serial number: 55931034303629 Coding: 310302 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_EPHVA18AU57X0000 001002 ROD: EV_EPHVA18AU57X0000.rod VCID: 37643BAFDF4D7D3AEE4AB51-8062 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 4H0-959-655.clb Part No SW: 4H0 959 655 C HW: 4H0 959 655 C Component: Airbag10.43 H40 0040 Revision: -------- Serial number: 003JG001932A Coding: 30314246323430303038554A305234483053 Shop #: WSC 02312 785 00200 ASAM Dataset: EV_AirbaAU10BPAAU64X 001014 ROD: EV_AirbaAU10BPAAU64X_AU64.rod VCID: 367A36ABD8478432F57C80D-8062 Crash sensor for side airbag; driver side: Serial number: 3575HRB405F6U4L4D8U0 Crash sensor for side airbag; front passenger side: Serial number: 3585HRB405B00TMOA1AK Crash sensor for side airbag; rear; driver side: Serial number: 3515JRB406504QLU4GIX Crash sensor for side airbag; rear; passenger side: Serial number: 3525JRB406504QLU68IS Crash sensor for front airbag; driver side: Serial number: 3554VRB405F070UGL1FS Crash sensor for front airbag; front passenger side: Serial number: 3564VRB405F070UGKPGA 1 Fault Found: 1050117 - Databus U1123 00 [008] - Received Error Message Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 4 Reset counter: 14 Mileage: 175709 km Date: 2016.11.27 Time: 13:55:36 ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb Part No SW: 4H0 953 568 A HW: 4H0 953 568 A Component: Lenks.Modul H08 0007 Revision: -------- Serial number: 90815JL10001C Coding: 000034 Shop #: WSC 02312 785 00200 VCID: 317005B73129A38AA08ECB9-8064 Subsystem 1 - Part No SW: 4H0 951 528 G HW: 4H0 951 528 G Component: E221 - MFL H04 0009 1 Fault Found: 00778 - Steering Angle Sensor (G85) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 13 Mileage: 175709 km Time Indication: 0 Date: 2016.11.27 Time: 13:55:36 Freeze Frame: (no units): 36.0 Text: 24A326013F014F4006 Clock: 38:01 h Text: O@v %£& ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb Part No SW: 4H0 920 910 D HW: 4H0 920 910 A Component: TDieGB------- H30 0297 Revision: 26110011 Serial number: 658161210593046 Coding: 33A708001B002600010000 Shop #: WSC 02312 785 00200 ASAM Dataset: EV_RBD4K 004033 ROD: EV_RBD4K.rod VCID: 2558E1E775E1FFAA4C164F9-8070 Analog_clock: Subsystem 1 - Part No SW: 4H0 919 204 H HW: 4H0 919 204 H Component: Analoguhr D4 H04 0210 Serial number: 1101209001575 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 4H0 907 468 F HW: 4H0 907 468 C Component: J533--Gateway H08 0213 Revision: -------- Serial number: 00000000074157 Coding: 00CD077D00 Shop #: WSC 02313 785 00200 ASAM Dataset: EV_GatewUDS 001025 ROD: EV_GatewUDS_AU57.rod VCID: 347E0CA3CE3B9622CB68EA5-8060 Battery Monitoring Control Module: Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181 Component: J367-BDM H07 0140 Serial number: 00000000005659395052 Voltage stabilizer: 1 Fault Found: 4224 - No Communication with Engine Control Module (SAE ECM/PCM) U0100 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 9 Mileage: 175513 km Date: 2016.11.23 Time: 19:35:08 ------------------------------------------------------------------------------- Address 30: Special Function II (J843) Labels: 8K0-907-440.clb Part No SW: 4H0 907 440 HW: 4H0 907 440 Component: STS H06 0030 Revision: S0H06000 Serial number: 00000000009258 Coding: 01010101000000000000000202 Shop #: WSC 02312 785 00200 VCID: 64DEBCE33E5B46229B889A5-8030 No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control (J197) Labels: 4G0-907-553.clb Part No SW: 4H0 907 553 C HW: 4H0 907 553 Component: LUFE-DAEMPFER H17 0096 Coding: 008001 Shop #: WSC 01236 210 01865 ASAM Dataset: EV_AirSuspe 003022 ROD: EV_AirSuspe_AU64.rod VCID: 2C4E14C3160BCEE293D8325-8078 2 Faults Found: 677124 - Ride-Height System C1047 07 [008] - Mechanical Failure Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Reset counter: 13 Mileage: 175600 km Date: 2016.11.26 Time: 12:10:24 0648 - Function Restriction due to Implausible Message(s) U1112 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 14 Mileage: 175709 km Date: 2016.11.27 Time: 13:55:36 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: None Part No SW: 4H0 959 760 F HW: 4H0 959 760 F Component: MEM-FS H08 0153 Revision: AA000000 Serial number: 00001002231940 Coding: 00383B0000057201000001010101102130313131202020 Shop #: WSC 02313 785 00200 VCID: 367A36ABD84784B2F57C80D-8062 1 Fault Found: 03332 - Motor for Height Adjustment 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 224 Mileage: 175513 km Time Indication: 0 Date: 2016.11.23 Time: 19:58:54 ------------------------------------------------------------------------------- Address 3B: Sensor Elect. (J849) Labels: None Part No SW: 4H0 907 637 HW: 4H0 907 637 Component: SARA 6D H02 0015 Revision: -------- Serial number: EJ1BPA310090CJ0 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SARA 006014 ROD: EV_SARA.rod VCID: 6CCED4C3D68B0EE2D358725-8038 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: None Part No SW: 4H0 959 793 F HW: 4H0 959 793 F Component: TSG FA H07 0162 Revision: -------- Serial number: 0000110310280 Coding: 011F12205E21628202080002 Shop #: WSC 02312 785 00200 VCID: 3C6E2483E66B5EE20338425-8068 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb Part No SW: 4H0 907 064 BB HW: 4H0 907 064 AB Component: BCM2 2.0 H23 0333 Revision: 00002001 Serial number: 0140221010 Coding: 011B0E2200B93C81B320C78408010000000000000000000000 0000000000 Shop #: WSC 02313 785 00200 VCID: 6AC2D2DBDC7F1052A14444D-803E Subsystem 1 - Part No: 4H0 951 177 Component: DWA-Sensor H01 0010 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 4H0 947 135 A HW: 4H0 947 135 A Component: Dachelektroni H11 0080 Coding: 010000 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: None Part No SW: 4H0 959 792 F HW: 4H0 959 792 F Component: TSG BF H07 0162 Revision: -------- Serial number: 0000111182888 Coding: 011F12205E21628202080002 Shop #: WSC 02312 785 00200 VCID: 3B6C279FE36559DA0A32591-806E No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 4H0-907-801.clb Part No SW: 4H0 907 801 D HW: 4H0 907 801 A Component: EPB-4 H03 0010 Revision: -------- Serial number: 00000000028373 ASAM Dataset: EV_ParkiBrake 001021 ROD: EV_ParkiBrake_AU48.rod VCID: 2940EDD719F9DBCA68FE139-807C No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb Part No SW: 4H0 907 357 A HW: 4H0 907 357 A Component: ....LWR12.... H02 0012 Serial number: 101208-0004-010 Coding: 11116F101000A300 Shop #: WSC 02313 785 00200 ASAM Dataset: EV_HeadlRegulBasic 005001 ROD: EV_HeadlRegulBasic.rod VCID: 2C4E14C3160BCEE293D8325-8078 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4H0 035 061 G HW: 4H0 035 061 Component: Radio U DAB H52 0097 Revision: AB001007 Serial number: 440L.0A7504196 Coding: 010103020100000001 Shop #: WSC 02312 785 00200 VCID: 2252FAFB64CF08122934ACD-8076 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb Part No SW: 4H0 035 666 F HW: 4H0 035 666 C Component: H-BN-EU H41 0239 Revision: -------- Serial number: 058L 0A7502571 Coding: 020101000001F1EF45108B1E00000003E001010000000000 Shop #: WSC 02312 785 00200 VCID: 2C4E14C3160BCE6293D8325-8078 Subsystem 1 - Part No: 8R0 060 884 N Component: EUR 2011 1205 Subsystem 2 - Part No SW: 4H0 919 604 C HW: 4H0 919 604 C Component: DU8 D4 SV NB H46 0021 Subsystem 3 - Part No SW: 4H2 919 600 D HW: 4H2 919 600 Component: E380 BDT D4 H09 0063 Subsystem 4 - Part No: 8R0 060 961 A Component: CD-Database 2712 1 Fault Found: 03157 - Functionality limited due to Communications Disruption 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 9 Mileage: 175492 km Time Indication: 0 Date: 2016.11.21 Time: 18:23:17 Freeze Frame: Text: ÿ Text: ÛJ ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 4H0 959 795 B HW: 4H0 959 795 B Component: TSG HL H09 0162 Revision: -------- Serial number: 0000110119863 Coding: 010F12204021628202080002 Shop #: WSC 02312 785 00200 VCID: 3A62229BEC5F60D2112454D-806E No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels: Redir Fail! Part No SW: 4H0 907 383 C HW: 4H0 907 383 C Component: Anhaenger H07 0100 Revision: 5H001001 Serial number: 00000137048799 Coding: 0100000000000000 Shop #: WSC 00000 000 00000 VCID: 2D4819C72D11C76A84A6279-8078 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4H0-907-441.clb Part No SW: 4H0 907 441 HW: 4H0 907 441 Component: SG Rueckfahrkamera 0030 Revision: --H04--- Serial number: 525 PA8J0YD0IX Coding: 1022002 Shop #: WSC 02313 785 00200 VCID: 65D8A1E73561332A8C968F9-8030 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (----) Labels: None Part No SW: 4H0 959 107 P HW: 4H0 959 107 M Component: HDSG-Modul H11 0036 Revision: 10011001 Serial number: 341000088 Coding: 0210044001 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_DeckLidContrUnit 001025 ROD: EV_DeckLidContrUnit.rod VCID: 3B6C279FE365595A0A32591-806E No fault code found. ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II (J773) Labels: None Part No SW: 4H0 907 412 HW: 4H0 907 412 Component: ALM H05 0004 Revision: -------- Serial number: 000000018573 Coding: 220000 Shop #: WSC 02312 785 00200 ASAM Dataset: EV_Ambie 001008 ROD: EV_Ambie.rod VCID: 63DCBFFF3B55419A6282911-8036 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 4H0 959 795 B HW: 4H0 959 795 B Component: TSG HR H09 0162 Revision: -------- Serial number: 0000110119831 Coding: 010F12204021628202080002 Shop #: WSC 02312 785 00200 VCID: 3A62229BEC5F60D2112454D-806E No fault code found. ------------------------------------------------------------------------------- Address 81: Gear Shift (J587) Labels: None Part No SW: 4H2 927 731 A HW: 4H2 927 731 A Component: GSM-RL H05 0081 Revision: 0R0D5012 Serial number: SN101109 0163 ASAM Dataset: EV_GSM2x3Mono 001014 ROD: EV_GSM2x3Mono.rod VCID: 2C4E14C3160BCEE293D8325-8078 No fault code found. ------------------------------------------------------------------------------- Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 945 HW: 4H0 980 945 Component: RGS-VL H05 0070 Coding: 00060000031F030000030800424CDA010000 Shop #: WSC 02312 785 00200 ASAM Dataset: EV_RGS_L 002004 ROD: EV_RGS_L.rod VCID: 6FF4C3CFE79DF5FAF63A1D1-803A 1 Fault Found: 12584197 - Function Restriction due to Faults in Other Modules U1113 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 6 Reset counter: 14 Mileage: 175709 km Date: 2016.11.27 Time: 13:55:36 ------------------------------------------------------------------------------- Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb Part No SW: 4H0 980 946 HW: 4H0 980 946 Component: RGS-VR H05 0070 Coding: 00060000031F030000030800424CDA010000 Shop #: WSC 02312 785 00200 ASAM Dataset: EV_RGS_R 002004 ROD: EV_RGS_R.rod VCID: 70F6C0B3FAA3EA02EF00065-8024 1 Fault Found: 12584197 - Function Restriction due to Faults in Other Modules U1113 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 6 Reset counter: 14 Mileage: 175709 km Date: 2016.11.27 Time: 13:55:36 End-------------------------(Elapsed Time: 05:47)--------------------------
2011 A8 Executive 3.0 TDI Quattro Last edited by Albert_Swafega; 27th November 2016 at 05:44 PM. |
