Old 2nd December 2016, 08:33 AM
Glad to know all was resolved. Will be cleaning f125 connector contacts on my car to fix 01119 error preventively. If it won't help will change the whole switch. Epic thread.
Edit: Is the electrical connector of F125 switch easily accessible?
(I wanted to start from replacing only the connector to new and then replacing the full switch if it does't help?)
I think the connector on the fly lead is easy to get at, several people have opened it up and checked/cleaned the contacts with mixed results. The problem I and others have had is wear/corrosion on the moving parts INSIDE the switch.
Old 2nd December 2016, 08:48 AM
Understood. Will change the full switch then.
Old 2nd December 2016, 09:47 AM
Sergei, you are not known for doing half-hearted jobs Given the construction of the switch (see my thread with photos) it doesnt give the impression that a squirt of electrical cleaner or any other form of repair would do the business. With mine, one (at least) of the contactors was damaged. It MIGHT have been possible to have built it up with solder but i wouldnt have given tuppence for it lasting. The F125 switch is £153 (IIRC) + VAT so it should give you peace of mind for another 100k
Old 2nd December 2016, 11:25 AM
Went to order the switch. Cheers David.
Old 2nd December 2016, 11:50 AM
Agreed. Cleaning the inside of mine has solved the problem for now, but its not a long term solution as the contacts are clearly wearing away. I was curious so it was worth a try but I have no idea how long it will last. It may be another 100K, but it may be a few weeks. Certainly if you have to pay a garage 4-5 hours to do the job there is no point whatsoever in skimping on £180 for a new switch.
Old 2nd December 2016, 12:09 PM
Another 3 days, a few more trips, still behaving and still no 01119 error
And another week has passed without incident . Clean VCDS scan - well apart from a low voltage in the alarm siren.
So as I said earlier:
I'm seriously convinced that all those comments about cleaning ABS sensors etc. are just coincidental and that the real cause of the 01119 error is a worn F125 switch.
Old 2nd December 2016, 12:12 PM
I did wonder, but forgot to ask yesterday. Just assumed as you turned up in the S8 to tow another away that it was behaving itself.
Old 2nd December 2016, 12:52 PM
glad to hear you got this sorted Andrew
Old 8th December 2016, 10:22 AM
2. Pulling out of a side road and accelerating the car only speeds up "gently" not "urgently" as I expect. No ABS/ESP warnings or symptoms. Only seen within the first minute or so of driving the car and not always by any means.
Interestingly, since having 'mended' my F125, mine is now doing this most of the time. The first 50% of the throttle does very little, but prod it a bit further and it takes off like a rocket. It happens mostly in 1st which is very annoying, but also randomly in other gears. If I'm in town pootling around at 30 and slow down for something it'll take a hefty prod to make it move, at which point it changes down to 2nd and goes a bit nuts. Its much better behaved in tiptronic, to the point I had to tow the FE home entirely in tip otherwise it would barely move. No codes either.
Time for a new switch methinks...
Old 8th December 2016, 11:08 AM
Check your brake pedal switch too. Had a similar problem with mine a few years ago, turned out to be iffy brake pedal switch contacts. I noticed the fault would tend to occur more after firm braking and tapping/wiggling the brake pedal before setting off again seemed to alleviate it.
