Old 14th May 2010, 05:44 PM
ulfilias ulfilias is offline
00283 - Front Left ABS Wheel Speed Sensor (G47)
Which wheel would be front left then ???
It all depends if your in front or behind the car. I took it to mean drivers side, particularly as thats where it appeared i had a noise. However on fitting the sensor today, The problems have re-occured. *sigh*
Interestingly snipping the senor off last night and driving home with just the break wear sensor hooked up fixed the ABS problem. traction control light was on perminantly though, but it did make the car more drivable than with an erroring sensor.
Old 15th May 2010, 08:30 AM
Usually from the position of the driver looking forward... So it's the passenger one in this case.
