Old 1st February 2015, 07:05 PM
Felly Felly is offline
Default S8 exhaust
I know some of you guys have wired the flaps in the exhaust open. Is this a difficult job or relative easy? Ud like to do it to mine but I'm having trouble finding out how to do it. Any help would be gratefully received.
Steve
Old 1st February 2015, 07:16 PM
Norretal's Avatar
Norretal Norretal is offline
It's easy mate, if I can do it anyone can
Have a look underneath at the back boxes and you'll see the vacuum units that operate the flaps. Shine a torch down the inner pipes on both sides and you'll see the flaps. Wedge them open and wire the linkages in that position with a piece of strong wire, job done. Probably easier with an extra pair of hands but once you take a look and understand how they're set up it'll make sense.
A8 Doc posted some pics in the relevant D3 section back in 2011 so take a look at them if it'll help.
Audi TT - 2015 - Ultra
Old 1st February 2015, 07:45 PM
Thank you very much, everyone on this forum are very helpful. Did it make of a difference? And sorry for the questions, would I be right on saying when in sport mode the flaps open up at all revs?
Old 1st February 2015, 08:24 PM
Conquistador's Avatar
The flaps open when more exhaust gas is forced through. They are not actuated with the throttle.
It's easy to keep them open. I cable tied mine open quite easily.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 1st February 2015, 08:43 PM
kele kele is offline
I used a large jubilee clip on mine. So far so good...
I would say at full throttle there is no difference (because they would have anyway be in the open position). However, on idle or light throttle there is a notable difference. A more pronounced bass sound.
Maybe also a perceived quicker pick up too...
Old 24th March 2015, 09:34 PM
mattsimis mattsimis is offline
Out of interest does the S8 exhaust fit onto a standard A8 4.2?
Old 20th December 2016, 07:59 PM
aTOMic's Avatar
aTOMic aTOMic is offline
Amazingly, the S8 system fits the (2004 at least) A8L! I thought it'd require adapters and welding but the only changes are the rear valance must be modified and the rearmost hangers unbolted, turned 180 degrees, remounted - and everything matches up! I've many photos I will post someday...
Tom
I'm in love with a car.
2004 4.2L Petrol A8L
Sage Green/Black (one of only five D3s thus colored sold in the US)
Old 21st December 2016, 10:21 PM
That's correct, the additional length is in the earlier part of the exhaust system and the rear sections are similar with the exception you've noted for mounting. I had a modified exhaust on my A8L when I got it which was sold to another member and it went straight into his S8 with no issues.
