Old 21st December 2016, 12:33 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Hope this helps
That does Matt. A real help. Ta.
Any idea how I get the intake housing off?
I think this blower is going to have to really make some serious noise before I rip the thing out in this weather!
2007 Mini Cooper S R56
Old 21st December 2016, 12:39 PM
Yes, see PDF, assuming this is the part you're referring to.
File Type: pdf vw-wi___rl_A.en-GB.A02.5104.59.wi__43811717.pdf (157.7 KB, 341 views)
Matt
Old 21st December 2016, 12:47 PM
Johnmed's Avatar
Bingo. I owe you another online Beer Matt. How do you get these PDFs, do you subscribe to have access to ETKA or something?
Old 21st December 2016, 12:53 PM
One day at a meet I hope
I have ELSA, the workshop repair manual, installed on my PC's. There are download links somewhere in the web, but I bought the CD's for £10 off ebay.
Matt
Old 21st December 2016, 01:01 PM
Johnmed's Avatar
Deffo. Hold me to at least 5 internet beers. I know what I'll be downloading later on.
Old 24th December 2016, 01:46 PM
Johnmed's Avatar
Ok, Merry Chrimbo all.
Managed to get this done earlier today.
Fiddly job that requires large ish Allen hexbits, 5.5mm socket/spanner and/or I think it was a T15 torn bit. Oh and double jointed child's hands. Not having those I managed with a bendy torx driver, saved the day essentially.
The ELSA guide says to remove both wipers, I managed just removing the nearside.
This is in no way a guide, but hopefully the pictures will help anyone who needs to do this themselves.
I reckon my blower had got noisy from water ingress, as the drainage ducts I think have been squished when the pollen filter has been replaced incorrectly; it's quite fiddly to do right I guess.
Took a good while to find screws that were hidden in different locations to the earlier D3s. Hope this helps, I think the pics explain the process pretty much.
I started by marking with tape the position of the wipers:
Remove plastics:
and nearside wiper arm with this:
Remove bracing that has 13 bolts:
This is the bugger, and it has two MORE tiny screws behind it. Don't forget those
These are the ducts that I think have been neglected:
All the best. John
Old 24th December 2016, 02:21 PM
Nice work John
In the Elsa guide there's a section about adding a seal to a joint to prevent water ingress.
Matt
Old 24th December 2016, 02:28 PM
Johnmed's Avatar
Yeah. I read that Matt. I may add some where it said, I'm not entirely convinced by the recommendation, but I ran out of time, and it can be done quite easily I believe in situ.
