Old 24th December 2016, 02:28 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Yeah. I read that Matt. I may add some where it said, I'm not entirely convinced by the recommendation, but I ran out of time, and it can be done quite easily I believe in situ.
2007 Mini Cooper S R56
Old 24th December 2016, 08:12 PM
Thanks John, useful write up
You didn't say what the result was - did you replace the blower motor or do something to lubricate it or what? If you replaced it what was the cost?
Old 24th December 2016, 08:45 PM
Johnmed's Avatar
Sorry. Yeah, I replaced it with a used blower. £70 from eBay. The old one functioned well bar the noise, it may have needed oil or new bushes, I don't know. Just wanted the awful sound gone to be honest. I may try and sort the old blower motor out, and keep it as a spare. Don't really have the time to muck about these days!
Old 24th December 2016, 08:48 PM
I have the same issue on a D3 so was interested in wether it was cured or fixed by replacing - thanks that's helpful
Old 24th December 2016, 08:53 PM
Johnmed's Avatar
Glad it helped. I was surprised at how many small screws needed removing. And you really do need some bendy tools and dollops of patience. Even by Audi's standards. Something to bear in mind if you do attempt yours. What concerned me was the noise of the old one, it didn't sound that bad. I guess the '8 is so quiet that any noise is a big deal. The replacement in the engine bay didn't sound that different, but inside the car was almost silent.
Old 24th December 2016, 08:58 PM
Thanks yes it seems variable in noise but is never more than a small squeaking noise, sometimes it is almost seeming to be assisted by the wind when the blower is on slow but there is more wind outside. If I turn up the fan speed it always goes, but it doesn't stop it getting on my nerves lol
Old 24th December 2016, 09:01 PM
Johnmed's Avatar
Mine was like a metallic cricket, then frog and only when cold. Then it began to scrape and groan. Really started to do my nut in by the time I changed it it sounded like aluminium ladders coming loose on a roof rack. Was worse when I slowed on slip roads. Was comically bad!
