The final firmware version - 0850 - originally came on the 5150 MMI CD and was on the 5570 one too. A VCDS scan for an AMI at the final level should like like this:- Address xx: Media Player x (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 xx and x vary depending on which optical bus interface the AMI is connected. Without access to VCDS you can check the SW part number and the level number - 0850 - using the 'red screen' in the MMI If you're not at SW 4E0 035 785F, which is the part number for the 0850 firmware, you need to update the AMI. For cars at 5570, this is not normally a problem if the AMIs been in the car a long time but a retro fitted AMI may not be at the correct level. Regards - Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
