Old 12th January 2017, 09:00 AM
My friend at work found these nice looking LiFePO4 batteries that could serve as starter batteries.
Or maybe not......
NOTE: These are Deep-Cycle Batteries for extended continuous use, not to be confused with High-Rate Batteries which are for starter applications only and not for extended continuous use.
Old 12th January 2017, 09:17 AM
Or maybe not......
I read that to mean that high-Rate batteries "are for starter applications only "while these deep-cycle batteries are also "for extended continuous use".
Either way, my main concern would probably be, how safe are these to use?
Old 12th January 2017, 09:35 AM
I decided it wasn't clear, hence the maybe
maybe not......
Old 12th January 2017, 10:19 AM
* edit *
yes I didn't spot that, could be that they may not have high enough discharge rating.
Continuous is 30A, but it doesn't say the peak rating.
Found another one with a high discharge rating but it does not have a battery management circuit so that's no good.
https://www.ev-power.eu/LiFeYPO4-bat...40AH.html#tab2
Old 21st January 2017, 08:32 PM
27litres's Avatar
27litres 27litres is offline
Deep Cycle batteries will supply their rated output continously for an extended period over a starter battery and will be generally rated lower for a similar size/capacity as a result.
For lead acid it has to do with their construction.
For Li type I'm not sure how/if they control output, I would think they were slow(er) discharge by design.
Provided the rated output from these batteries is adequate (you need at least 300 amps, preferably 500-600), you can easily start a car with them (I've got a couple of those LiPo mini jump start packs for emergencies - they work great even with only having about 200 cranking amps (despite claims)).
My only concern would be accepting charge from the alternator - they pump quite a wallop energywise...
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
