Old 17th January 2017, 05:32 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Drains look clear, an initial hose over the outside of the door had water dribbling out of the drain halfway along the door to the outside world
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 18th January 2017, 05:09 AM
Ameiseuk's Avatar
Had more of a look at the door last night. You can see from the pic where the door trim material has detached from the card.
When I opened the door last night there was a steady trickle of water from the very bottom of the door in the direction of the arrow - there seems a lot of water in there in comparison to any other car I've ever owned?
Is this the only door drain?
Daily drive:
Current 'Project':
2000 Audi S8 FL
www.whall.co.uk
Old 18th January 2017, 03:55 PM
johnny_quattro's Avatar
Default Similar sitch
I have a similar problem on mine, which I intend to take a look at shortly. Damage to my door 'card' is much worse than your one so I'll try and grab a photo and upload it. I've just had a look on my ElsaWin application and can see that there are two sunroof drains to the front of the car and a further two drains leading to the back. The front drain may be a possible culprit as it ends up tucked inside the door jamb, through a hole situated just above the meaty bottom hinge - picture/diagram attached so you can see what I mean.
Name:	Screenshot from 2017-01-18 16:50:28.png
Old 18th January 2017, 08:39 PM
There should be several drains in the door, all along its length. Possibly they are blocked up with something, or possibly the plastic is missing from behind the door card?
Old 18th January 2017, 10:29 PM
Ameiseuk's Avatar
Got an hour free this evening and had a proper poke at the door.
Sunroof drains are all ok, nice trickle of water from behind the rear wheels and down the A pillars above the lower front door hinge.
I sprayed the garden hose liberally over the outside of the closed door and found that water is running down the outside of the door card from the top of the black triangle above the rear view mirror. Runs over the speaker grille and pools nicely along the plastic step inside the car!
Adjusted the door striker plate and fiddled with the double lip door seal (the harder one running round the outside of the window frame) and it seems to have stemmed the flow.
Going to have a look at the passenger side too - if one is doing it then it's almost certain the other is too.
Still need to pull the door card off, dry it out and fix the peeling material at the bottom of it.
10 door clips due here tomorrow from TPS to fit when the door is apart.
Now discovered I'm going to have to paint the black window frame - previous owner hasn't been kind to the paintwork
Daily drive:
Current 'Project':
2000 Audi S8 FL
www.whall.co.uk
Old 19th January 2017, 11:39 AM
Default Inconclusive
I had a look at mine, albeit in the darkness. Both darinage tubes end up poking out of the hole just above the hinger and looked ok to me. I'll probably have to get some old curtain wire or similar to give it a good poke through although I suspect that the water ingress may be down to having less than perfect door seals? Another job to do on a slightly warmer day, I think.
Old 19th January 2017, 05:23 PM
Ameiseuk's Avatar
I opened the sunroof and carefully poured water into the black surround, water drained quickly front and back out where they should have gone. If you're going to poke wire or similar up the drain hoses make sure the end is folded over so it's not sharp and likely to poke holes in it.
Your door looks similar to my issue - I ran a dull screwdriver down between the two 'lips' of the seal, dug out a load of caked crud then gave it a genlter clean with an old toothbrush and some soapy water. At least if it gets past the outer seal it can now run down the outside of the 'A' pillar
Daily drive:
Current 'Project':
2000 Audi S8 FL
www.whall.co.uk
