4.2 Tdi Auxiliary Heater
Hi,
My Auxilliary heater seems to be running still after an hours driving. Is this ok? It seems to me that it is using fuel unnecessarily. Is there a way to change the settings? I can't find anything in MMI Thanks Jon
2007 4.2tdi Quattro Sport. Valcona black leather, Extended leather, Sports comfort Seats, Fr&R Heated seats, 20" wheels, BOSE, Media Interface, TVIM, DAB, CD changer, Bluetooth, Reversing Camera, Auto dim mirrors, Blinds, Soft close doors, Elec Boot, Keyless entry, Finger print read, TPMS, BI Xenon Active lights, LED indicators, LED puddlelights from door mirror when door closed. |
i dont think my one works
It should be automatic, so there are no settings, and I see no reason at all why it would be running.
Stupid question, but it is definitely the webasto chugging away, and not the suspension air compressor or something else over running ? Have you run VCDS against it to check for errors ?
For parts enquiries and Forum User Administration please contact customer services directly, not me - enquiry@a8parts.co.uk, www.a8parts.co.uk, or call 01642 783537 The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black , 2007 TT Roadster, 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Yep definitely coming from the Aux heater exhaust, front drivers side just in front of the front suspension mounts
You can override the usual automatic temperature based activation by using the Auxiliary Heating menu in the AC part of the MMI. Could it be that it is constantly set to on? Do you have a little flashing heater icon on the main dash display by the time by the rev counter (I think?). Otherwise could be a faulty temperature sensor as it is set to come on under 5 degrees and as long as your low fuel light/warning is not on.
Lee 2017 Nissan Leaf Tekna |
Thanks for your reply. I don't have any control under the AC menu on the MMI.
I am in the process of getting VAGCOM I'll know more then. Seems like a sensor out though doesnt it. Anyone know a part number or cost? Thanks
Do you have the ' set up ' button on the climate control , there's an option in there for aux heating on or off
The Webasto coolant heater was fitted to all D3 A8 diesels, and the Q7 4L also.
And the A2 diesel, and likely some others. It is designed to bring the engine up to temp rapidly rather than waiting for the diesel block to eventually do its thing. It shouldn't need to run for more than about 10/15 mins really. Optionally, although not available in the UK brochures, you could get auxiliary heating which uses the same webasto heater, but has a second battery and water pump to allow the car to pre heat with the engine off. This has the setting in the MMI and usually a remote control also. Retrofitting this to warm up with the engine off isn't particularly hard. You can enable the controls in the MMI with vagcom, but without the pump to move the water round the heater will just boil the water and shut itself down due to overheating. Jon, I would assume, has a standard UK spec car, with no Aux heating, but will have the Webasto heater as standard, and it is this which is over-running. Interestingly, they often fail to work, but over running is not something I've heard of. Either way, there's no MMI config to it (unless someone has been fiddling). So, I guess the heater thinks the coolant is below desired temperature which is why it is still running making a sensor a reasonable bet. You've not mentioned, so I assume the car is getting up to and maintaining 90 on the temp gauge ? Vagcom should be able to tell you a lot, and ever if there are no errors, the measuring blocks should be able to tell you what temperature the webasto thinks the coolant is at....
Thanks. Yep thats right.
Car sits at 90 no problem in all conditions and down to -4 we had last week. Once I've got the VAGCOM I'll let you know. Cheers Jon
