Old 30th January 2017, 11:15 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Hydro-Mounts
I need two new engine mounts (Hydro-Mounts) as VCDS is telling me there is no signal.
I know people say you can leave them but I don't like things being broken, so I got to replace them.
Audi wants about £340 per mount and i'm not prepared to pay that.........well, I am if there's no alternative but I want to see if there's any alternatives.
So is there any alternative supplier for these mounts?
[center]
06 3.0TDI Quattro:
Options:
Old 30th January 2017, 11:45 AM
HPsauce HPsauce is online now
Have you asked our sponsors?
And are these the right sort: http://www.ebay.co.uk/itm/Brand-New-.../282328911611?
Old 30th January 2017, 11:46 AM
The engine mounts are marked 'Avon', not sure if it's one of these...
http://www.avon-group.co.uk/industries/automotive/
http://www.avonauto.com/
http://www.avonauto.com/pdf/Source/V...ets%202007.ppt
Could be worth giving them both a call
Matt
Old 30th January 2017, 11:57 AM
ScottD3's Avatar
Part Numbers for the 3.0TDI with ASB engine is 4E0199381FH and 4E0199381FJ.
HP, I don't fit 2nd hand buses, mounts or anything rubber related if I can help it.
Thanks Matty, I'll drop them a message.
[center]
06 3.0TDI Quattro:
Options:
Old 30th January 2017, 12:36 PM
They look like they are for a D4 4.2 looking at the code
Old 30th January 2017, 05:52 PM
Joe2.0E Joe2.0E is offline
Personally, I wouldnt waste the money on them.
I had one of them replaced for free under warranty one time my old D3 3.0TDI was in for a service. I did'nt notice any difference before of after.
Obviously it will throw a fault code but I can live with that.
Old 30th January 2017, 07:00 PM
jza8's Avatar
jza8 jza8 is offline
You can avoid the fault-code by disconnecting the mounts and plugging in resistors sold by Audi themselves
2010 Audi A8 4.2 TDI
Old 1st February 2017, 08:17 PM
I have replaced these type of mounts ...........hydro oil , vaccum type, viscous type on various models ...jags , mercs ,volvos .....ive not been able to tell a blind bit of difference driving and to drop subframe or flap about lifting engine up i just dont think its worth the agro , but its your call .
Old 2nd February 2017, 08:37 AM
Lee, That sounds like god advice.
Does anyone have details about this Audi resistor mentioned earlier?
Old 2nd February 2017, 08:40 AM
ScottD3's Avatar
Its still a rubber mount, ignoring the electronic side of it.
Rubber breaks down, like all bushes and needs replacing and these being hydro they can leak.
The error might be a premature warning and they don't need replacing at all but they will need replacing at some point.
Surly putting a resistor in is like turning the stereo up when your front arms start to knock?
[center]
06 3.0TDI Quattro:
Options:
