Old 31st January 2017, 02:34 PM
Originally Posted by Jon_viola View Post
Thanks for your replies
This was after the 1st scan and then a clear. Not sure that worked though. Is there a procedure with the ignition after hitting clear?
The modules spoke fine, if you look at the list below, I was just a little slow getting the ignition on....
Can anyone help with the EGR coding?
as well as doing a general clear all I would also go into each module showing a non-clear and manually clear each module
