Old 13th February 2017, 06:47 PM
I used to have 17" winter wheels on my PF S8, but they wouldn't fit over the brakes when I moved to FL.
Thats strange as the S8 FL manual states that 17" wheels ARE what is provided as winter wheels
Old 13th February 2017, 06:56 PM
Indeed, I remember reading that myself.
In fact they did just clear, by about 1mm, but the balance weights fouled on the front calipers. Spacers might have fixed that.
And mine were not OEM S8 wheels, but rather the Avus design from, I think, an S3 or S4. Correct offset etc. but alloys.
I can imagine that a steel wheel, if that was the OEM winter wheel, could easily be made in a suitable profile to clear comfortably.
Old 13th February 2017, 09:00 PM
The 17" flat fives from the non-sport model should clear the Brembos - thats what I have on my racecar.
The wheels advertised are 8x17 as well afaik but the spokes look much thicker so I'd say its unlikely these will work with the Brembos, but they should work for all the other D2 brake setups.
What size tyres are on them?
Old 14th February 2017, 09:33 AM
Darius Darius is offline
They are 235/55/17, I believe standard d3 size for 17inch wheels
Old 15th March 2017, 02:42 AM
Bump.
Will give them away for £200 as need to clear space.
