Guys; following an ongoing forum discussion with Ross Tech regarding A8 D3 Battery Manager [BEM] ECUs, I wondered if any of you with 'early' A8s [2003 and 2004 cars] could help with survey re. Firmware levels? [Yes, I know there aren't many out there]
![]() 'Early' A8s had a Version 1 ECU where the battery cable connected underneath the ECU rather than into the middle of it. However, the good thing for these early BEM ECUs is that you can read the label easily [the V2 ECUs, with the cable going to the middle tend to make it difficult to read the ECU label]. I'm trying to correlate actual HW/SW/FW numbers to label numbers, so to assist, you really need a VCDS scan of the ECU as well as to look at the label. All I'd like to know is the first three lines of the VCDS scan of the ECU 61 and the Part number / SW number / version numbers [two numbers to the right of part numbers] off the label. Note: I'm doing this because some ECUs seem to have a mismatch between the versions on the label and the versions 'found' by a VCDS scan. Thanks - Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! Last edited by JulianHicks; 17th February 2017 at 11:57 AM. |
Here's mine. I think it's been replaced in the past as it's old software and the WSC is all zeros...
Code:
Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0160 Revision: 00000000 Serial number: 00000000013302 Shop #: WSC 00000 000 00000 VCID: 5DB18073842382AAE5-8008
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000018428 Shop #: WSC 02313 785 00200 VCID: 204F0F15F34C1D3E5E-8074
Regards - Julian BTW, the original ECUs seem to be 'good'. Yours may have been in the car since new - have a look at the date on the label. Some of the early A8 ECUs tended to have zeros where you don't see them later. My [very early] Telephone ECU has zeros in various places.
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! Last edited by JulianHicks; 17th February 2017 at 11:49 AM. Reason: Add text |
Regards - Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
Ah sorry, I'll look later... I'm at work.
And I note that you're following the long running thread at Ross Tech. Looks like your BEM level of 0160 indicates no history logs are stored in it!
![]() Julian
Julian,
Here is mine, SWMBO is out in the car so I'll try and look at it tomorrow. Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0160 Revision: 00000000 Serial number: 00000000010676 Shop #: WSC 00000 000 00000 VCID: 5DB1B54184D4E3C924D-8008 Subsystem 1 - Part No: 000 915 105 AK Component: von VA0 301008803E Coding: 303030393135313035414B56413033303130303838303345 Shop #: WSC 73430 210 01865 No fault code found.
See pics
Control Module Part Number: 4E0 910 181 C HW: 4E0 915 181 C Component and/or Version: J0644 BEM H12 0550 Software Coding: Work Shop Code: WSC 00149 210 03776 Additional Info: 4E0915105A von BA2 5753086081 Additional Info: Geraet 03776 VCID: 20486C38F30A224011-8074 i'll check the label tomorrow you.
