Old 17th February 2017, 08:00 PM
That makes more sense; can anyone confirms it's an option?
Or is there a "reset" available via VCDS?
Old 19th February 2017, 08:26 PM
Not according to Elsawin - all that says on it is to disconnect either the multi-plug or battery for 15 minutes.
Old 19th February 2017, 08:40 PM
Haven't looked in there for a while, but IIRC the TCU is at the top of the pile in the ECU box under the bonnet?
Old 19th February 2017, 09:38 PM
Can't remember, but Elsawin means the plug from the gearbox rather than the TCU although I suspect it would have the same effect.
Old 20th February 2017, 12:12 PM
Pug Pug is offline
I've tried the pedal reset procedure in the D2 S8 and it did behave different. I think it resets the gearchange. For example, the car had been driven energetically previously and all the shift points were quite high, even if driven carefully. After doing the pedal reset it did behave very differently.
Current: MY2019.5 Ford Ranger Wildtrak 2.0 BiTurbo
A8/S8 - A gap to fill.
Multi-Franchise Main Dealer during the day, Amateur vehicle enthusiast by night.
Old 20th February 2017, 12:18 PM
Interesting, do you recall what procedure you used exactly?
I'm thinking that having had various "issues" with mine this would be a useful thing to do.
Old 20th February 2017, 12:44 PM
Pug Pug is offline
Instead of holding the pedal down, I found a guide which said to switch on the ignition without starting, then over a period of 20-30 seconds, slowly press the accelerator pedal all the way to the floor, and then release over a period of 20-30 seconds in the same way. I'm not sure what confirmation the car is supposed to give apart from the different driving characteristics.
