Old 24th February 2017, 05:12 PM
Works great with my D2 S8 for checking/resetting fault codes, etc. No idea about winding back brakes on a D3 though.
There was a discussion about the OBDeleven here a while ago:
http://forum.a8parts.co.uk/showthread.php?t=10897
Old 24th February 2017, 06:34 PM
Simonbartlett Simonbartlett is offline
Thanks for the link, sounds like it's worth a try. I would like vcds but can't find a used cone and the new ones are a bit pricey
Owner of a 2008 A8 3.0tdi SE
Old 24th February 2017, 07:22 PM
I have made the purchase £48 delivered, can't wait to try it now 😃
Old 24th February 2017, 08:02 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Really good bit of kit, use it on D2 S8 and it works on a 2012 Q7 as well
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 24th February 2017, 09:20 PM
gninnam gninnam is offline
Agreed, for the money its good - use on my TT - recommend
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 27th February 2017, 12:21 PM
When i plug this in will it list modules ( ecu's ) and will it tell me their part numbers ? I need to know what steering module my a3 has for fitting Cruise.
Thanks
Old 27th February 2017, 01:13 PM
Thanks
I've just checked with mine and it would seem so.
After you've plugged it in and connected via the app, it scans for modules. You'll then get a list of all the modules it found. If you select the relevant module, then select 'info', it seems the part number is listed there.
A few screenshots ...
Name:	2017-02-27 13.58.45.png
ID:	15779 Click image for larger version
Name:	2017-02-27 13.58.55.png
ID:	15780 Click image for larger version
Name:	2017-02-27 14.00.09.png
ID:	15781 Click image for larger version
Name:	2017-02-27 14.01.11.png
